Autocrossing & Roadracing Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results
Best approach to catch oversteer?
Old 01-08-2007, 12:43 AM
  #41
Hans Delbruck
Hans Delbruck's Avatar
Originally Posted by petefias
What is the best method to catch an oversteer due to too much gas in a turn? I've seen too many times when countersteering in an oversteer situation just snaps the car in the other direction when it hooks up again. Is that caused by too much countersteering, letting up on the gas or both?
Same approch to be used with AH/TC on and off?
Nothing wrong with learning this "by the book."
Correction - Pause - Recovery.
The tail swings out, you countersteer. That's the Correction phase.
The car responds to your steering input and the tail stops its momentum. It's now poised to swing back the other way. That moment is the Pause. And it's your cue to begin
The Recovery. You need to get the steering wheel back to straight.
That's the basic way to look at it. This is covered in GREAT DETAIL in the book "Going Faster" by Carl Lopez/Skip Barber. Anything you ever wanted to know about car control, finding the fastest line, lift-off oversteer and throttle-on oversteer and just about everything you will encounter on the track, is covered in this book. Sounds like not many here have read it. Well I didn't either until I totalled my Z06.
Regarding saving over-rotation caused by power-on oversteer... your first try should just be *don't lift*, just keep steady on the throttle with a countersteer-pause-recovery. If that's not enough, try countersteering and breathing the throttle back to about 70%.
If you can't afford a driving school or aren't near to one... this book is the best $29.95 you'll ever spend.
Old 01-08-2007, 03:43 AM
  #42
2KZ28CAM
2KZ28CAM's Avatar
Sounds like sound advice to me.
This forum, and the amazing level of experience and expertise of it's members are why I keep coming back over and over.
No matter what I think I know, there are always others here that can tell me otherwise in a respectful manner. For that reason I am thankful to be a part of this forum, regardless of capacity.
Old 01-08-2007, 09:49 AM
  #43
VetteDrmr
VetteDrmr's Avatar
Received 1,398 Likes on 749 Posts
Originally Posted by davidfarmer
I tend to agree that Autocross does NOT teach the same kind of car control that you need for high speed events. It is still good experience, but not the same..
I agree that autocross and track experience is different. However, autocross experience is a ton better than zero experience, autocross events are more numerous than track days, and you can drive your car to and past the limits (usually the driver, not the car) without fear of damaging the car.
A comment was made about driving less than 10/10 on a track being useless. That may be the case for someone working on competitive driving, but a DE is Driver's Education, and running at 8/10 (or 6/10, or whatever level) should be set by the driver's comfort level. Most of us (at least me) have to take the car home at the end of the day.
One thing's for sure: if I ever move away where I can't run at our local autocross facility (Mineral Wells), I'm going to be in for a rude awakening. It may not be the same as running a track, but it's sure not slow!
Have a good one,
Mike
Old 01-08-2007, 10:49 AM
  #44
Lancer033
Lancer033's Avatar
Originally Posted by Timz06
Throttle induced oversteer, easy to control just countersteer, either lift a bit, or keep the throttle the same.
works like a charm...even in a DD Tahoe in the rain trying to haul a__ across town like I was 5 min. ago. ...and people try to say this has no application in the real world.
Old 01-08-2007, 12:23 PM
  #45
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Originally Posted by Bink
Am I reading this correctly?
- I don't think Schumacher would favor this setup.
Mario probably would.
Not favor trailing throttle understeer? That is exactly what the F1 teams strive for. Off throttle control so they can trail brake or out brake with the most control.
The opposite is trailing throttle oversteer which is not controlable if the back of the car is trying to swap ends. Outbraking is usually accomplished via trail braking.
Then when the throttle is applied again, the car needs to go neutral or slight and I mean very slight understeer. This will allow early throttle application on corner exit.
If the car has power on over steer, then the driver has to be perfect on the timing to apply power or he has to lift to tidy the back end up.
So there is the answer to the original question. Throttle control to stop oversteer is a major part of the driving equation. The tires have only so much traction available. So if they are spinning or sliding with throttle application on corner exit, then you either have to reduce the power on or reduce the side load from the corner.
No fast race car brakes only in a straight line. So stability under braking while turning is essential.
Later,
Lou Gigliotti LGM
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Old 01-08-2007, 07:13 PM
  #46
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Later,
Lou Gigliotti LGM
Lou - thanks for the explanation it's greatly appreciated . I think I now understand the points you've made.
But, I still have to differ on MS's setup requirements. When Berger and Alesi took over at Benneton they were unable to drive MS's car at full tilt (10/10ths). At 9/10ths no problem with turns. 10/10ths it swapped ends and off they went. Neither Alesi, nor Berger, could drive it.
Isn't that trailing throttle oversteer?
joel
Old 01-08-2007, 07:25 PM
  #47
LG Motorsports
joel
It might be. It depends if the oversteer was with Throttle on, Throttle off, or Neutral throttle. Either way, it took MS to drive it.
Go to Youtube and search "Michael Schumacher Driving style", and you can watch a great documentary that shows a data trace of Schumacher vs his team mate. both were great drivers, but Shui made small corrections and kept his corner speed up as he made the corrections. It is a great video that you will love watching.
I get goosebumps watching this video.
http://www.youtube.com/watch?v=Uk2p2...elated&search=
It also helps explain how two world Class drivers can be so different. So just think how far back the rest of us are.
Then watch this one: http://www.youtube.com/watch?v=qUEKm...elated&search=
Thanks
LG
Old 01-08-2007, 08:43 PM
  #48
96CELT4
96CELT4's Avatar
... In an oversteer I intuitively countersteer the car, but many times the car just snaps into an opposite slide, fishtail, and then I countersteer the other direction, then the car hooks again and fishtails. ...
...I think I'm too late with straigthening the steering wheel that causes me to dart off the other way or should I keep on the gas to prevent unloading the rear?
I think what may help you in understanding why the car hooks when it does is to think about what's going on with the tires. When you have the car in an oversteer situation the rear tires no longer have grip. They are sliding in a sideways direction, yet are still turning in a forward direction because hopefully you are still feathering the gas. As long as the tires are still spinning at a high rate of speed and sliding sideways they will probably never regain traction. The "hook" comes in when you have already counter steered. The rears start to come back to the same orientation as the front tires. However, if the rotation of the tires slows enough to match the forward direction they are starting to head back in, the rears will suddenly regain traction. Now you have the fronts trying to go in one direction and the rears trying to take you in the opposite direction. That's the hook that starts the cycle all over again. Only this time it's usually into a wall!
So the trick is timing when the rears regain traction in relation to your counter steer input. You control when that happens by modulating the throttle. Allow the rear tires to regain traction when they are inline with the fronts and you'll prevent the hook. I think almost everyone knows intuitively what needs to be done, it's just the timing that takes practice.
Old 01-08-2007, 09:26 PM
  #49
Westwopper
Westwopper's Avatar
Can't believe no one had read this!!!!
I am not a fan of T/C on the track. If the car slips and the T/C comes on, I have a hard time correcting for it. In my experience, it transfers a lot of weight. I don't have AH so I leave the T/C off.
With the active handling in full on mode, you will learn how to be smooth in this car. The smoother you are the more slip angle you will be able to use, then progress to the Comp mode.
It is very difficult for an instructor at a DE to feel comfortable with you driving at the limit of the car, much less your skill limit. Because of the performance limit of our cars, as our skill sets increase we begin to carry tremendous amounts of speed. I try to make it clear where we will likely have issues as speed is picked up and what to do if that happens. Most of all, just make sure you or the student is not driving over their head.
Old 01-08-2007, 10:40 PM
  #50
robvuk
robvuk's Avatar
I didn't think you could even drive a C5 with the TC on at the track. On the other hand, I don't have a problem driving with AH if you're smooth. I make all my students run with Competition mode.
Old 01-08-2007, 11:22 PM
  #51
Westwopper
Westwopper's Avatar
My cheif instructor thinks its funny to give me students in 1 type of car. Mustangs. Last time I had a student with a twin turbo cobra. and a late model LX 5.0, punched out. No T/C for those guys.
Old 01-12-2007, 10:49 AM
  #52
burners
burners's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Lou, those videos are very interesting and I think it demsonstrates a lot of Schumacher's talents but (obviously) that first video with him at Benetton is rather old. I have seen comparison data (in "Racecar Engineering", I believe) between Schumacher and Barrichello. Apparently Schumacher's Ferrari setups are a bit different than at Benetton. He actually maintained 15% throttle while braking to reduce pitching (I think it's safe to guess for other reasons as well). That alone would allow a different setup than what would normally be considered safe or fast.
Old 01-14-2007, 06:52 PM
  #53
az55
az55's Avatar
Default Whoa, Sparky!
Originally Posted by Andi
...me f$cking around in my old Supra back in the day at Motorsport Ranch.....
http://www.boostaholic.com/supra/med...-MSR-Drift.wmv
That's the best, most responsible way to learn car control.
Me? I learned by f$cking around and powersliding that Supra everywhere on the street... and parking lots..... every time it rained, etc........ But hey, I was 19 and owned the Dallas highway races at the time too. At least I lived through it. And now, thanks to my past, I'm a badass at car control, and I can go race totally smooth and not-sideways or flip a switch in my head and go win a drift contest.
I'm just trying to tell y'all the safer way to do it (track day) where you'll still actually learn something.
Somebody suggested a driving school. Umm... a driving school won't teach you car control. They'll teach you the by the book $H!T and then they'll get scared when you get sideways because (a) they don't know you, and (b) sideways is slow. I've been a student and I've been an instructor, so take it from me. My point is, schools do have their purpose too, but it's a different one... go to a school to learn how to sit in the car, the racing line, how to heel & toe, how to go fast, etc.
Go to a track day and just screw around alone and feel around for the limit if you want to learn car control. That, and maybe a also try a wet parking lot. Preferably one without light poles or curbs or other cars.
Most importantly, make sure ALL the electronic $H!T is turned off. I don't mean that homo competitive mode. I mean the AH/TC OFF mode. The one where you hold the button down for 5 seconds in a c6 or press it once in a c5.
Andi
P.S. Sorry for the tome.
I was with you up to this point. I too learned as a "street fighter" in canyons and parking lots but you are incorrect about driving schools.
Spring Mountain indeed teaches extreme car control. One exercise is done through a series of cones with the AH off and the instructors specifically push you beyond the limits of control. I had a ball(sideways mostly and steering with the throttle) and the novices got the chance to experience this first in a safe place without risking their car or the lives of others. Another exercise focused on avoidance and skid control with all nannies turned off including ABS. They make you do these until you demonstrate that you can control a car in an emergency, then they teach you to drive fast! (And they're
F$CKIN GOOD at it, too)
Cheers from Arizona
Quick Reply: Best approach to catch oversteer?
