Rectangular Intake with Oval Heads ????
Old 12-29-2006, 05:40 PM
standup
standup's Avatar
Default Rectangular Intake with Oval Heads ????
What are the consequences of using an LS6 intake manifold (designed for rectangular port heads) with Edelbrock RPM heads....(the Edelbrock literature says their heads are oval port but flow like rectangular port) ??????
Old 12-29-2006, 08:50 PM
shafrs3
shafrs3's Avatar
Fuel pooling at the lip between the head and the intake.
Old 12-29-2006, 09:04 PM
itsonlyairandfuel
itsonlyairandfuel's Avatar
I've done it with no noticable problems. In fact it ran pretty good. Ron B.
Old 12-29-2006, 09:21 PM
73, Dark Blue 454
73, Dark Blue 454's Avatar
Actually Edelbrock calls these heads "roval" port,..which I guess is a "tweener". But why not spend $150 and get the matching intake? Having a big stair-step in the runner can't be good.
Old 12-29-2006, 10:49 PM
kaiserbud
kaiserbud's Avatar
I am in the process of changing from Chevy OEM Rectangular Ports Heads to Brodix RaceRite Oval Ports. I did not want to deal with the mismatch on the intake, so I bought an AirGap Oval Manifold to maintain best flow. Isn't that what it is all about?
Here are the Brodix #'s:
RaceRite BB Oval: 270cc Intake/119cc Chamber, Flow 340 Intake/236 Exhaust
RaceRite BB Rect: 294cc Intake/119cc Chamber, Flow 342 Intake/236 Exhaust
Their website data: http://www.brodix.com/heads/raceritebb.html
I am by no means an expert, but from what I read/was told, the flow on the oval is actually faster with the volume being very close. The oval is more streetable and the rectangular might be better for REALLY high rpms.....guys - be gentle.......
Old 12-30-2006, 12:10 AM
standup
standup's Avatar
Originally Posted by 73, Dark Blue 454
....But why not spend $150 and get the matching intake?.....
That would be too simple .....you're right about the step, because the heads and intake are not matched and I'm now sure there's going to be lots of metal interference......staying with the stock or L36 manifold means I have to use a Q-Jet.....I'd buy the Performer 2-0manifold, but not sure if it will fit under the stock BB hood ?????
Originally Posted by kaiserbud
I am in the process of changing from Chevy OEM Rectangular Ports Heads to Brodix RaceRite Oval Ports. I did not want to deal with the mismatch on the intake, so I bought an AirGap Oval Manifold to maintain best flow.......
Thanks for the Brodix link, haven't seen those heads before ....I've got a stock mid 70's 454 and I'm sure I'm going to need small (110cc minimum) heads to build compression because I didn't want to go into the bottom end.....I may have to anyway because I've got flat top pistons ???????
Do you have an L88 hood to get the AirGap manifold in there ????? If not tell me how it's done....
Old 12-30-2006, 12:24 AM
standup
standup's Avatar
BTW, what I'm trying to acheive is a top end rebuild on a stock '77 454 motor....which is probably no more than 8.5:1 compression with 113cc chamber heads.....
....so I want to change heads, cam, intake & carb to improve low end torque...and it all has to fit under the stock BB hood.....
Old 12-30-2006, 02:51 AM
Little Mouse
Little Mouse's Avatar
Take a look at the edelbrock performer high compression 454-0,
part #60499, it has 100cc comb. chambers, 219/188
valves, 290 runner.
Old 12-30-2006, 03:23 AM
standup
standup's Avatar
valves, 290 runner.
Those are the exact heads I'm looking at.....just need to make sure a low rise, Holley based intake will fit under my BB hood....I've already been told I should have bought an L88 hood to "widen my horizons"..... ...but I'd like to make this work without having to change the hood....again....
Old 12-30-2006, 05:56 PM
kaiserbud
kaiserbud's Avatar
StandUp - I do have an L88 hood - very happy with extra clearance and especially the looks
Old 12-31-2006, 10:12 PM
sxr6
sxr6's Avatar
Standup; word is useing the rect intake works just fine on a oval head just doesn't work worth poop the other way.
Assuming you have stock flat tops that are 16-20 thou down the holes you need small cc heads to get any decent compression. The flattops in my 454 are down 16 thou & with 101cc (290) heads & a 020 steel head gasket my compression works out to just under 9-1.
Old 01-01-2007, 03:51 PM
yellow-fever
yellow-fever's Avatar
Default My exact same situation
I have a stock 74 454 and am also contemplating either a top end rebuild with the 100cc Edelbrock heads, new cam, carb, etc. and I also want to keep it all under the stock hood. I have done the homework and found that there are 2 and exactly 2 manifolds that will work in our situation: (1) LS-6, which will give a port-mismatch with the oval heads but I am told actually works fine, OR: (2) Edelbrock Torker II, which is not a good manifold in any way. It has very small runners and and open plenum design (?).
My choice was the LS-6 manifold. Found a NOS one on Ebay in perfect condition. Now the only thing I have to figure out is what ttpe of shape my short block is in. If it needs a rebuild, I will probably pull out the entire motor and drop in a ZZ502, using the LS-6 manifold on it.
I will be interested to follow along with your project, standup, as we are trying to do exactly the same thing with our cars.
Old 01-02-2007, 12:20 PM
Wrencher
Wrencher's Avatar
I'm running a rectangle port 3x2 manifold on my stock oval port heads with no problems. Is it perfect performance wise? No, but until I install the LS-7 heads and a better cam, it'll work and I get to drive it. I put about 500-800 miles a month on mine and try to limit down time
Hans
To Rectangular Intake with Oval Heads ????
Quick Reply: Rectangular Intake with Oval Heads ????
