Lets talk about c6(not a z06) suspension
I really want to know is there any good way to stop the c6 rear end from oversteering a lot. I have a full time track only c6 which i dont use for many autocrosses but mainly just for road & track events.
i got the car to be at its limits many times and still the rear end steps out little more than i wanted.
any really good aftermarket shocks that can help with my problem. i do know a brand called koni's are out there, can i just have a professional tuner install these in the rear and can i only do rears. I know these shocks are about 250 bucks a piece.
watch the third clip.
http://clipshack.com/Clip.aspx?key=8FC3B618D7E6CFAB
PLEASE CLOSE THIS THREAD
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Looks to me like you are pinching the car in the corner and not running out to the edge of the track at corner exit. Once you hit the apex, you need to free the car up and just let it run to the outside of the track at exit. You don't really have an oversteer problem until you are using up all of the track and have drive slower just to stay on the pavement.
Originally Posted by Miaugi
You could try getting a larger front sway bar or a smaller rear one, that should reduce/remove the oversteer.
Originally Posted by stapleking
Just buy and install the GM T1 kit - all your problems will go away. 'Cept the one with the driver.....
come on guys need advice on the oversteer problem. i sat in a c5 z06 those felt more planted than the c6, but one is race inspired sports car while other is just a base sports car.
btw i have the z51 package.
i need suggestions on the shocks now as i already ordered the z06 rear sways.
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
Moderator
Received 3,579 Likes
"I really want to know is there any good way to stop the c6 rear end from oversteering a lot. I have a full time track only c6 which i dont use for many autocrosses but mainly just for road & track events.
any really good aftermarket shocks that can help with my problem. i do know a brand called koni's are out there, can i just have a professional tuner install these in the rear and can i only do rears. I know these shocks are about 250 bucks a piece."
You may want to consider buying a set of adjustable endlinks. They will allow you to control the amount of stiffness applied by the bars.
http://www.vansteel.com/index.cfm?fu...&SubGroup=1899
Originally Posted by shopdog
Other way round. A bigger front bar makes the rear loose. A bigger rear bar makes the front loose.
You can also play with tire pressures to make the rear tires stick more, front tires stick less.
To reduce oversteer:
A) more front tire pressure or less rear tire pressure
B) larger rear tires or smaller front tires
C) larger front sway bar or smaller rear sway bar
D) less negative camber at the front
E) lower compression in the rear shocks, and/or higher rebound in the front shocks
F) less throttle input
But really, how much is a lot? If you rather new to tack driving, you might simply be able to correct the drivers inputs to the car and change nothing on the car itself! Slowing the rate of steering input can help, a little more respect for the throttle pedal helps, choosing a line that allows you to go full throttle just before arriving at apex can also help, finally, slow down earlier (and a little more).
Finally, a car will have more grip with softer springs, bars, and shocks. Stiff springs, bars, and shocks make the transistion from slipping to sliding easier (in both directions) and more controllable but it is not necessarily faster.
So how much is a lot? In my opinion, a 'lot' is when the steering wheel is more than 15 degrees in the opposite direction as the turn. If the steering correction only goes to straight ahead, you are not really oversteering, but you have simply found where the car has gone truly neutral.
Mitch has some good information to absorb. And stiffening the rear end will make the car oversteer more - just ask *any* front driver. That's why some front drive guys take their front sway bar off completely, to get the rear end to swing more.
Plus, you mentioned the addition of better tires in your arsenal come next year... does that mean you are running the OE runflats now? Just getting rid of the runflat lead-lined sidewalls will drastically change the way your car transitions, off curbs, et al.
Before changing anything drastically, figure out which tires you're sticking with first.
nope not if i get only the rears, as it will loosen up the front.
Retired & lovin' it!
Many different bits of information here, but I didn't see what I think is the most critical question......have you had the car on a good (and I empahasize "good") alignment machine to see where you're starting from? Shocks alone are not going to change the oversteer/understeer characteristics of a car...whether they be Koni's, Bilstein' or Joe Schmo's. You need to know very accurately what caster, camber & toe settings you have & then work from there. Once you have the alignment right, you can then go to different size sway bars, adjustable link ends, etc. I'm not familiar with your location, but a good, competition chassis shop should have a laser alignment machine like the new Hunter & will now what caster, camber or toe setting to dial in, depending upon your description of the handling.
