C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
What tire pressure should I use at 1 mile run?
Old 06-05-2006, 03:55 PM
Mylzi
Mylzi's Avatar
Default What tire pressure should I use at 1 mile run?
I usually have is 2.4bar.
How much higher pressures I should use at 1 mile 'top speed' run?
Old 06-05-2006, 04:48 PM
8388's Avatar
St. Jude Donor '14
I always run 40 psi at all four corners. about 2.8 bar.
Old 06-05-2006, 05:04 PM
Mylzi
Mylzi's Avatar
Ok. Thanks
Higher tire pressure helps?
Old 06-05-2006, 05:05 PM
BRICKMAN
BRICKMAN's Avatar
Cruise-In VII Veteran
b
Old 06-05-2006, 05:40 PM
Jeffvette
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Less rolling resistence
Old 06-05-2006, 06:30 PM
DDSLT5
DDSLT5's Avatar
Just like the hineys in jeff's avatar!
Old 06-05-2006, 08:39 PM
FU
NCM Lifetime # 982
Support Corvetteforum!
FU's Avatar
Location: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Be sure the LTPWS are out of the car
Old 06-06-2006, 02:18 PM
Mylzi
Mylzi's Avatar
I have heard about those problems.. But havent had any yet..
Dont do high speed runs very often anyway.
Old 06-06-2006, 02:21 PM
Jeffvette
Jeffvette's Avatar
All it takes is once.
Old 06-06-2006, 03:24 PM
8388's Avatar
St. Jude Donor '14
I think the of combination heat and age is what causes the plastic on those sensors to fall apart. I took the ones on my 91 Z off, and will be doing the same on my 93 when ever a tire change is needed. It's always best to check the air pressure before drive. As far as I'm concerned, those sensors are useless. If you're serious about keeping the right pressure at all times, nothing beats a pressure gauge.
For those that don't drive much. Keeping the proper pressure at all times helps the tires from developing a flat spot, which is something you want to avoid, especially if you get into the triple digits every now and then.
To What tire pressure should I use at 1 mile run?
Quick Reply: What tire pressure should I use at 1 mile run?
