Sponsored by: DashLynx
Best 12-inch sub?
Old 08-09-2001, 09:14 PM
01redcoupe
01redcoupe's Avatar
Default Best 12-inch sub?
Who makes it and how much does it cost? I was thinking Rockford Fosgate
Old 08-10-2001, 12:08 AM
Speed-Racer
Speed-Racer's Avatar
Default Re: Best 12-inch sub? (01redcoupe)
You ask for the BEST?
Speed-Racer
Old 08-10-2001, 02:36 AM
Bullitt
Bullitt's Avatar
Actually there is no such thing, you have to choose one based on characteristic you are looking for-Sound Quality, Ability to Play Loud or How Low Can it Go. The other thing to look for is how it will behave in the size and type of enclosure your car can accomodate. Stick with companies that are Speaker companies not electronics companies, they typically will make a better product because that's their specialty. Radio makers like Kenwood, Alpine, Pioneer, Clarion etc should be avoided. You should be prepared to spend anywhere from $199.00 - $999.00 for a quality 12" Woofer that will handle gobs of power, be more durable and actually reproduce low frequencies accurately. Then you have to pay for a quality enclosure to be installed.
Most important make sure you have a quality amplifier capable of driving the woofer you choose. It's better to have more power than not enough.
Hope this helps.... :D
Old 08-10-2001, 05:17 AM
Sam Lin
Sam Lin's Avatar
From your id I assume you have a C5. you'll have some difficulty fitting a 12 in there easily and keeping stock look. If you're willing to give up some space, then it's doable. Otherwise, Illusion Audio has the only 12 that'll flush mount into the rear center. If mounting and airspace aren't a concern, I'd check out Audiomobile's MASS series, they're incredible. SPL and SQ, believe it or not. It's basically an SQ sub with record excursion, for SPL. I have one of the Illusion 12s, haven't put it in the car yet.
Sam
Old 08-10-2001, 06:08 PM
92TripleBlack
92TripleBlack's Avatar
Default Re: Best 12-inch sub? (Sam Lin)
Bullitt and Sam Both have good answers but lets put things in perspecitive. Look at how much you want to spend. Under $250, 250-500, or $500+ for the sub without box, amp, crossover, wire, etc. Installing a 12" sub in a car will cost about $1,000 if the cost of just the sub is about $250 if you include everything. A $1,000 sub will need about $3,000 to do it justice. I rate Rock Fosgate as a decent under $250 sub with JBL and MTX rounding out the group. Next level we're talking Boston Pro, A/D/S, Soundstream Reference, and the next level again Focal, Autobahn, etc. I have a Boston and I am very happy. Its powered by 300w continuous and crossed over at 200hz in a sealed box. It will blow out my ears at full so I have to stand outside the car and use the remote to turn it up higher. It also warps the rear deck of the convertable when the top is down with each thump.
Hope this helps
92TripleBlack
P.S. Here is the one I want to check out next...
The Audiobahn AWT 12
250oz Double Stacked Strontium Magnets | Power Handling: 2000 watts R.M.S. | Frequency Response: 20Hz – 500Hz | Efficiency: 87.3dB | Bolt Tight Motor Structure | PHAT 2 Inch Foam Surround | Titanium/Aluminum Cone | 4 Inch 4-Layer AVS Voice Coil | Dual 2 Ohm Voice Coils | 1 Ohm or 4 Ohm Operation | Mounting Dimensions: Depth; 6 3/4 Inch Diameter; 12 3/4 Inch
You can get there through this site. It costs $699 plus amp plus..... http://www.audiobahninc.com/index2.htm
[Modified by 92TripleBlack, 4:11 PM 8/10/2001]
[Modified by 92TripleBlack, 4:18 PM 8/10/2001]
Old 08-10-2001, 07:27 PM
Speed-Racer
Default Re: Best 12-inch sub? (92TripleBlack)
BTW - the size of the magnet has nothing to do with the quality nor power handling of the sub
I would like to hear other's systems and compare to my $35 sub I got on Ebay. I'm not ashamed of it's price 'cause it sounds fine by my ears - and that's what counts.
Listen to some 12"ers at stores and compare.
Speed-Racer
Old 08-10-2001, 07:29 PM
Speed-Racer
92TripleBlack - man that sounds like a mean bass you have - would love to "feel it'
Speed-Racer
Old 08-11-2001, 02:55 AM
Bullitt
Bullitt's Avatar
Default Re: Best 12-inch sub? (Speed-Racer)
Which sub did you buy on Ebay for $35.00?
Old 08-11-2001, 06:40 PM
Speed-Racer
Default Re: Best 12-inch sub? (Bullitt)
Model = PYM1278
12" PRO SUBWOOFER W/70 OZ. MAGNET
- 12" PRO SUBWOOFER
- 8 OHMS IMPEDANCE
- POLY COATED PAPER CONE
- STAMPED STEEL BASKET
- 70 OZ. MAGNET
- 400 WATTS RMS/1000 WATTS PEAK
- FREQUENCY RESPONSE: 55HZ - 5KHZ
That's the one. It sells for around $69.99. I think there are many subs for around that price and I am tickled pink at this one. Actually I am thinking of getting 2 of these for my PC stereo system (for mp3's)
Speed-Racer
Old 08-13-2001, 12:45 AM
WhiteHorse
WhiteHorse's Avatar
Location: Wichita, KS, USA Vote John McCain in 2008 God=Santa Claus 4 adults
D'Angelos. You can find them all over Massachusetts. Best subs around. Check out their pepper steak sub. Mmmm mmm good.
:smash:
:jester
To Best 12-inch sub?
Quick Reply: Best 12-inch sub?
