Interior still hot!!!
#81
Just a suggestion on your heat shield shape.
With your current shape, won't that capture radiant heat from the sides of the pipe and direct it up into the tranny tunnel?
Would a better design be just an inverted U with the peak over the centerline of the pipe? The peak would act as a trap for the heat and keep it from the interior until it was blown aft by the draft.
We seem to be running in many of the same threads. Same car, same threads I guess....
Cheers
Cheers
#82
Originally Posted by CMYC4GO
My 76 used to get like a brick oven inside. The OEM heatshielding was crap. I ordered some space age stuff from JC Whitney, pulled up all the carpet, and went to work. Covered everything that was coverable with this stuff, and it was a difference of night and day. I forget what it's called, but supposedly it's used by NASA. It came in a big roll (enough to do 3 Corvettes) and if I remember right, it was about $80 for the roll.
Thats cheaper than Ecklers kit.... I will look at JC Whitney... thanks for the heads up.
BLVette75
#83
Cheers
Cheers
Thanks...
I noticed that too...good learning experience here,and I hope I have helped some others as well...
Rich
#84
Cheers
Rich
#85
Originally Posted by rihwoods
.....Tried a short cut by tacking shield to pipe...
I'm working on several of the suggestions here in this thread, as you know it gets a little warm here in AZ.
#86
[QUOTE=82Vette'ster]
'From the photo the shield looks to be fairly dark. You'd get little better results if you spray it with high temp aluminizing or make it more reflective some how. White on the side that faces the interior will also radiate less heat. Just .02 "
I'm going to paint it.May even add thermotec to pipe side.
Arizona set some heat records this year....was following weather in Phoenix...
Rich
Originally Posted by rihwoods.....Tried a short cut by tacking shield to pipe...[/QUOTE
Rich
#87
Originally Posted by Indy Year 25
I bought this heater control manual shut off valve at Autozone. I have not installed it yet, but I think it will look like it belongs. This is part number 84707, it cost $11.99 (last summer). I believe they have a couple sizes.
#88
Vent seal restoration
A problem I discovered with my '69 is that the soft foam that seals the vent doors down in the kick panel area is completely gone. It looks impossible to remove the flap doors without drilling the rivets that hold them together. Any ideas?
#89
ESU
#91
I wasn't familiar with Doc Rebuild, but I like that they have some things that I haven't seen anyone else selling.
ESU
