Northern California Northern California
50/50 or higher windshield fluid?
Old 02-16-2009, 05:19 PM
csun213
csun213's Avatar
Default 50/50 or higher windshield fluid?
Hi, does anyone know where I can purchase a 50/50 or higher windshield fluid? The auto part stores that I called said they don't carry such a high mix since it does not get really cold here in CA.
I am thinking about using windshield fluid for meth injection (for safety only and not for added power). This way I can still have my windshield washer function.
Old 02-16-2009, 05:40 PM
bullitt4110
bullitt4110's Avatar
Its really hard to find Charlie. When I was doing this I had a buddy at an auto parts store order some and not sell it through the store, I dont have that connection anymore though. It was made by Peak and it was called Deicer -30* and it was purple in color.
Old 02-16-2009, 05:51 PM
RichieRichZ06
Supporting Vendor
Support Corvetteforum!
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
And even that stuff is only 30% methanol. It is hard to find in CA because I heard it was illegal to sell.
Old 02-16-2009, 06:03 PM
bullitt4110
Ya he wasnt allowed to sell it through the store. It works though, my IAT's dropped about 60-70* with that stuff.
Old 02-16-2009, 06:05 PM
csun213
csun213's Avatar
What do you guys think about the idea of purchasing 100% meth and then mix it with 50% distilled water. Then I would know that I have 50/50 or even make it 60/40. My question now is, is there any downside using this mixture for cleaning my windshield?
Old 02-16-2009, 06:07 PM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
I don't know how safe it is for your paint or anything. Why not just run 100% methanol. At prices now, it is probably just about the same price as the window washer fluid per gallon.
Old 02-16-2009, 09:00 PM
Mikeceli
Mikeceli's Avatar
I bought some at a Chevron station, in Truckee, last week.
Envirowackos got it banned in most of cali.
Old 02-16-2009, 11:09 PM
briann510
briann510's Avatar
Most of the Chevron stations that have the larger inside stores carry the below 32 degree windshield washer fluid here in the bay area.
Old 02-16-2009, 11:17 PM
bullitt4110
Thats good to know.
Old 02-16-2009, 11:26 PM
aligator
aligator's Avatar
Kragans auto had it.
Old 02-17-2009, 12:04 AM
csun213
csun213's Avatar
Don't really want to install another tank for meth and I still want to use my windshield washer, it comes in handy in some of our cruises. (bugs)
Does anyone know how 50/50 meth/water mix will effect the paint?
Old 02-17-2009, 12:09 AM
csun213
csun213's Avatar
Actually, I just called them and all they have is the standard fluid which is good up to 32F and not the ones with high meth with is rated for much lower temp.
Old 02-17-2009, 12:48 AM
redtopz
redtopz's Avatar
Any station in the mountains sells the washer fluid rated for below freezing. Even Auburn I think. That said, I use 50/50 in my truck for both meth injection and window washing with no problems.
Old 02-17-2009, 01:21 AM
C5Spirit
C5Spirit's Avatar
Charlie..get the washer fluid and cut it 50% with the methanol...that should be ok.
I live on the edge and use 100% methanol
Old 02-17-2009, 01:23 AM
C5Spirit
C5Spirit's Avatar
Methanol is $6.00 a gallon at Hubbard's in American Canyon. It might be hard on wipper blades??
Old 02-17-2009, 11:31 AM
Exotica
Exotica's Avatar
Charlie, that is exactly what I would do. In fact I intend to do the same thing but with a 90/10 mixture.
Old 02-17-2009, 01:00 PM
jhong321
jhong321's Avatar
Just buy the 30 % washer fluild and add a little meth to it
I don't think you can buy the 50/50 anymore. But if you look at walmart you will find the 30% mix.
To 50/50 or higher windshield fluid?
Old 02-17-2009, 04:29 PM
C5Spirit
C5Spirit's Avatar
What will he have if he takes 1/2 of the washer fluid out and replace it with methanol?
Old 02-17-2009, 04:39 PM
csun213
csun213's Avatar
Good question. Would it be better if I add 1/3 meth to the washer? Just worried that too much meth mixture would not be good for the rubber, plastic, paint, etc.
Old 02-17-2009, 05:38 PM
jhong321
jhong321's Avatar
You figue if you have about 30% meth in your washer fluid and it holds 2 gallons and you want 50/50
1 Gallon = 128 Ounces 30% (meth 38.4 ounces 89.6 ounces )
so take out about 1/s gall and add half gall of meth anf you will be around 50/50 (maybe a little more)
Just make sure you have a 2 gallon washer tank
Quick Reply: 50/50 or higher windshield fluid?
