When do you change your oil?
The following 5 users liked this post by Wife said I could:
BandDirector (04-19-2024),
billclerm (04-18-2024),
derbs24 (04-19-2024),
o2bnkc (04-23-2024),
Warp Ten (04-22-2024)
Received 1,579 Likes
2023 C8 of the Year Finalist - Modified
2022 C8 of the Year Finalist - Unmodified
2021 Corvette of the Year - Unmodified
Winner 2020 C7 of the Year - Unmodified
When cars first came with on board oil change calculators there was a lot of discussion around whether the owner should go by what the car says or something more frequent…
BMW kicked this off when they started including 4 years free maintenance. Owners quickly noticed that oil change frequency changed from every 3,000 - 5,000 miles to suddenly 12,000 or 15,000 miles. Although oil quality has vastly improved over the years along with engine manufacturing methods.
Two questions:
Approximately what mileage are owners seeing before the car recommends an oil change?
Do you wait until the car asks for an oil change or use your own schedule? (3,000 miles? 5,000 miles?)
Many thanks!
Two questions:
Many thanks!
Received 19,390 Likes
'20-'21-'22-'23-'24
I change the oil in my cars when the OLM gets down to 10% or less.
GM (a well as many vehicle manufacturers) spent a lot of time and money developing a system that indicates oil life based on individual driving habits rather than the archaic one-size-fits-all service interval that were in owners manuals. In many cases the oil change frequency was too short and in some too long.
The GM OLM has 3 pathways:
1. Engine revolutions – Oil life starts with a fixed number of revolutions and will decrease with each revolution. Cold / hot coolant temperature readings have multipliers that reduce engine revolutions quicker depending on deviation from a standard oil temperature for the vehicle.
2. Mileage from last reset – the OLM is capped at 7,500 miles (12,070 km).
3. Time – This pathway is a liner function. The oil life will drop to 0% after 1 year regardless of the amount of engine revolutions or how many miles since the reset.
Path 1 is an algorithm that identifies cold starts, high load, sustained high speed, short trips, short trips in cold weather etc.
Path 2 is odd since other OLM systems do not use mileage as a factor. Mileage does not directly effect oil quality. Possibly included to coincide with published schedule.
Path 3 is to ensure oil additives have not depleted so 1 year.
The following 3 users liked this post by gdb069:
Moderator
Received 3,589 Likes
Annually, unless the OLM says otherwise.
Received 8,874 Likes
Follow the owner's manual & OLM. My Corvette is annually because it sees ~1k mi/ year. Btw - my BMWs are 7,500 - 10,000, not 12-15k
I am also adding oil to engine to keep the level up where it is supposed to be.
The OLM takes into account service interval... Are you saying you are burning/ losing oil tracking it?
The OLM indicated "Change Oil Soon" at 2,500 miles and about nine months on the clock. I found out that the OLM is based on time and not miles, so the 2,500-mile message seems unrealistic. Since this is the original oil, I'm going to change the oil and filter anyway. When changed I don't expect to change the oil again until the transmission service is due at two years or 7,500 miles whichever comes first. can the OLM be manually set to correspond with the mileage or every two years?
https://www.corvetteforum.com/forums...post1606731541
“One thing I can touch on and clear up.....the GM oil life monitor operation and my statement that ZDP (or ZDDP as you tend to call it here...most of the API literature just sticks to ZDP so I tend to use that) depletion is the basis for oil deterioration.
My spelling is poor but ZDP stands for zinc dialkyldithiophosphate which , as it sounds, is an anti-wear compound comprised of zinc and phosphorus.
ZDP is dispersed in the oil so as to be at a potential wear site if a surface asperity happens to break thru the oil film thickness causing the dreaded metal-to-metal contact. A molecule of ZDP must be present at that moment to prevent microwelding at the contact site which will cause material transfer, scuffing, scoring, wear and catostrophic failure. The concentration of ZDP in the oil will determine if there is ZDP present to work it's magic. The greater the concentration...the more likely a molecule of ZDP will be there...and vice versa.
By nature, ZDP is sacrifical. As ZDP is "used up" at a wear site to prevent micorwelding the concentration of ZDP decreases.... So...if you measure the ZDP concentration in engine oil in a running engine it will decrease at linear rate based on engine revolutions. Any given engine has a certain number of high potential wear areas where metal-to-metal contact could occur due to reduced film thickness and/or surface asperities....areas such as rubbing element cam followers, distributor gears, rocker arm pivots, push rod tips, etc...... The more of these areas the more ZDP depletion. The more often these features come in contact the greater the ZDP depletion. That is why, generally speaking, ZDP concentration in the oil, for any given engine, will decrease at a fairly linear rate when plotted versus cummulative engine revolutions. The more times it turns the more contact the more chance for wear the greater the depletion. This is as much of a fact as I could quote ever and is really not speculation or anything. It is proven beyond a shadow of a doubt in many studies. That is why it is ONE of the basis for determining oil life remaining and why it is THE basic premis of the GM oil life algorithm. It is only ONE of the things that determines oil life...but it is the one thing that can be tied to engine operation in a linear fashion and estimated very accurately by accumulating engine revolutions via a counter.
The GM engine oil life monitor counts engine revolutions and accumulates the number for the basis of the oil life calculation. It then adds deterioration factors for operating temperature, start up temperature, soak times, ambient, coolant temperature, etc... There are a LOT of factors that "adjust" or affect the slope of the deterioration but the fundamental deterioration is traced back to the ZDP depletion that is inescapable with engine revolutions. The specific rate of ZDP depletion is readily measurable for any given engine so that is the fundamental item that is first calibrated for the oil life algorithm to tailor it specifically to that engine.
You would obviously like to get the oil out of the engine before the ZDP concentration gets so low that it is ineffective at being at the right place at the right time and preventing engine wear so that becomes the long term limit on oil life for that application.
The other things that determine oil life such a acid build up, oxidation, petane insuluables such as silicon from dust/dirt, carbon or soot build up from the EGR in blowby, water contamination, fuel contamination, etc.... are all modeled by the multipliers or deterioration factors that "adjust" the immediate slope of the line defined by the engine revolution counter as those items can be modeled in other ways and accounted for in the immediate slope of the ZDP depletion line.
The algorithm was developed over the course of many years by several lubrication experts at GM Fuels and Lubes, spearheaded by Doctor Shirley Schwartz who holds the patents (with GM) for the algorithm and the oil life montitor. I had the luck of working directly with Dr. Schwartz when the idea of the oil life monitor first progressed from the theoretical/lab stage to real world testing/development/validation. There were fleets of cars operated under all conditions that deteriorate the oil life for any and every reason and , thru oil sampling and detailed analysis of the oil condition, the algorithm was developed, fine tuned and validated to be the most accurate way invented yet to recommend an oil change interval by. As just one example, I have seen cars driven side-by-side on trips, one towing a trailer and one not, for instance, to prove the effectiveness of the oil life monitor in deteriorating the oil at a faster rate just because of the higher load, higher average RPM, higher temps, etc...and it works flawlessly.
The oil life monitor is so effective because: it is customized for that specific vehicle/engine, it takes everything into account that deteriorates the oil, it is ALWAYS working so as to take into account THAT INDIVIDUALS driving schedule, and it tailors the oil change to that schedule and predicts, on an ongoing basis, the oil life remaining so that that specific individual can plan an oil change accordingly. No other system can do this that effectively.
One thing is that I know personally from years of testing and thousands of oil analysis that the oil life algorithm works. There is simply no argument to the contrary. If you don't believe me, fine, but, trust me, it works. It is accurate because it has been calibrated for each specific engine it is installed on and there is considerable testing and validation of the oil life monitor on that specific application.
Oil condition sensors in some BMW and Mercedes products are useful, also. They have their limitations, though, as they can be blind to some contaminates and can, themselves, be contaminated by certain markers or constituents of certain engine oils. Oil condition sensors can only react to the specific oil at that moment and they add complexity, cost and another potential item to fail. One other beauty of the GM oil life monitor is that it is all software and does not add any mechanical complexity, mass, wiring or potential failure mechanism.
There is considerable safety factor in the GM oil life monitor. Typically, I would say, there is a 2:1 safety factor in the slope of the ZDP depletion curve....in other words, zero percent oil life per the ZDP depletion is not zero ZDP but twice the concentration of ZDP considered critical for THAT engine to operate under all conditions reliably with no wear. This is always a subject of discussion as to just how low do you want the ZDP to get before the oil is "worn out" if this is the deciding factor for oil life. We would tend to be on the conservative side. If the oil life is counting down on a slope that would recommend a 10K change interval then there is probably 20K oil life before the ZDP is catostrophically depleted....not that you would want to go there...but reason why many people are successful in running those change intervals.
There are entire SAE papers written on the GM oil life monitor and one could write a book on it so it is hard to touch on all aspects of it in a single post. Hopefully we hit the high spots. Realize that a GREAT deal of time, work and energy went into developing the oil life monitor and it has received acclaim from engineering organizations, petroleum organizations, environmental groups all across the board. It is not some widget invented in a week and tacked onto the car.”
#33
I wonder how many oil threads I've read since I got my first computer in 1995(Gateway). I've been on forums for my cars, trucks, motorcycles, snowmobiles and yard equipment.
#34
a quick Google of “2010 BMW oil change intervals” resulted in several answers. The first three were
From German Cars of Sarisota
- your recommended service interval for an oil change is every 12,000 miles or 12 months
From Bimmerpost
- 7.5k miles or every 6 months
From Santa Monica BMW
- Even your BMW owners manual’s recommended an oil change every 15,000 miles
#35
#36
Received 4,734 Likes
#39
I drove BMW’s exclusively for decades and have seen all sorts of oil change intervals and other changes….
From Bimmerpost
From Bimmerpost
My owner's manuals for my '22 & '23 M vehicles both say 10k or 12 months. The service indicator may recommend changing it earlier depending on driving conditions. Obviously manufacturers' recommendations change over the years. Doubt it anything to do with BMW covering the regularly scheduled maintenance or Chevy not covering it.
Acpantera (04-20-2024)
