Air Fuel Ratio? 12.4 to 1 too rich?
Old 12-21-2004, 08:37 AM
steve40th
steve40th's Avatar
St. Jude Donor '03 & '05
Default Air Fuel Ratio? 12.4 to 1 too rich?
I have a 396 LT1 with 30# injectors, long tubes, Hot Cam (yes it is a little small for this motor)58mmT Body, MSD ignition. After getting it tuned, I had it dynoed, 400rwhp 428ft/lbs tq, but the fuel pressure had to be dropped to 36#'s(lowest I could get it before screw came out on F/P regulator) and the air fuel ratio on wideband was 12.4 to 1. Is there any power left if I get it recalibrated on the tune to where I can get the air fuel ratio leaner? or is this okay on a N/A motor, automatic etc?
ps 93 LT1 Speed Density motor
Old 12-21-2004, 08:45 AM
STL94LT1
STL94LT1's Avatar
You may pick up a couple more horsepower going to 13:1. But, 12.4 is a very safe, yet still powerful tune.
Old 12-21-2004, 09:37 AM
65Z01
65Z01's Avatar
Cruise-In II Veteran
I had the '88 on a dyno last Sat. and the operator told me the same thing.
Old 12-21-2004, 09:49 AM
0ski_dwn_it
Former Vendor
ski_dwn_it's Avatar
The 30# injectors are too large for your motor, which is why you had to have the pressure down so low to achieve a reasonable AF mixture. THe problems with droppping below 38psi are the injectors start not delivering the correct amount of fuel - they for a lack of better words, start to sputter the fuel, instead of atomizing it for a better more efficient mixture.
You are not alone - most people over inject their setups...which leaves them right where you are currently at.
Even my good flowing 434 is over injected with 30# injectors. 24-26# ers would have been a better choice for me, which would have allowed me to run 45-50 lbs pressure for a much better atomization of fuel.
Your tune can be programmed to allow for a higher pressure at WOT, but what your basically doing is turning the 30lb injectors into a smaller injector, so what most don't get is why not just get the smaller injector to begin with.
Old 12-21-2004, 01:02 PM
steve40th
steve40th's Avatar
Ski, Can I just install smaller injectors? Then raise the fuel pressure back up?
Old 12-21-2004, 01:14 PM
gbody5
gbody5's Avatar
I'm not ski, but yes.
Old 12-21-2004, 01:36 PM
0ski_dwn_it
Former Vendor
ski_dwn_it's Avatar
Yeah as long at the fuel curve tuned into the chip follows the same characteristics of what the smaller ones do. And they should.
Old 12-21-2004, 02:11 PM
steve40th
steve40th's Avatar
Thanks, Should I go with a 24# SVO injector? And what pressure to start out?
Old 12-21-2004, 02:18 PM
STL94LT1
STL94LT1's Avatar
Personally, I would just stick with the 30 lb injectors. I really doubt that the little if any gains you will see from the 24's would be worth the price of new injectors and a different tune.
Old 12-21-2004, 02:24 PM
luvmy92
luvmy92's Avatar
Hmmm... well I have a 385 with the 30# FMS injectors and Racetronix Fuel pump kit, and have the fuel pressure set at 47 psi. My a/f is 12.7/1 all the way from 3500 to 6k I believe (need to check the sheet). I was told while it was being tuned that my stockers were too small and ended up getting the 30's.
Mike
Old 12-21-2004, 02:29 PM
FD2BLK
FD2BLK's Avatar
What injector constants did the tuner try? I have 36# injectors and my tune was stupid lean at 50 PSI untill the tuner found a constant that matched up with my injectors and motor combo. I can asure you that 30# injectors on a LT1 396 are not to big and if properly tuned should alow you to run 41 PSI and be fine. Because of the wide opinions on injectors I decided it is best to use what ever injector your tuner is most comfortable with for your particular combo, in my case my tuner said he would like to see a 36-42# injector and I couldn't afford the FMS 42's (And did not feel I needed them) so I wen't with the 36's). In terms of the tuner I used I can only say that the twenty or so loacal people who used him all highly recomended him and that I gained 31 RWHP and perfect drivability, Zero cam surge, and a 900 RPM idle.
Old 12-21-2004, 03:47 PM
steve40th
steve40th's Avatar
FD2BLK, who tuned your car in Charleston. I know Jamisons Custom Corvettes has PCM4LESS do it I believe, or More Performance? Other than jamisons, I dont know of any tuner in Charleston
Old 12-21-2004, 05:07 PM
luvmy92
luvmy92's Avatar
MORE Performance uses Jim Smith mostly... the same person that tuned my car.
Mike
Old 12-21-2004, 05:13 PM
steve40th
steve40th's Avatar
PCM4LESS did mine and very good tune as well as support.
Old 12-21-2004, 05:24 PM
FD2BLK
FD2BLK's Avatar
Nobody in Charleston can dyno tune a LT1 properly that I know of. I used Carolina Auto Masters in NC. I had it down to More and CAM but no one local had used More and Jeff at CAM has a great reputation among the F-body LT1/LS1 croud so I decided on CAM.
Old 12-21-2004, 05:33 PM
steve40th
steve40th's Avatar
Thanks, When they dyno tuned your car, what software did CAM use to get data for tuning, ie Tuner cat, LT edit etc.?
Old 12-21-2004, 05:54 PM
FD2BLK
FD2BLK's Avatar
He used a wideband O2 that worked with the DynoJet software, and Data master hooked to my ALDL. I am not sure what he used for tuning but I believe it was Tuner cat because my bin file is a normal bin file rather then an LT1 edit file. I have tuner Cat and it will accept either LT1 edit or Tuner cat files and I believe they will both tune the same parameters so it is not a big deal what is used to change the tune as long as a wide band is used and when used with Data Master it gives the compleate picture
To Air Fuel Ratio? 12.4 to 1 too rich?
Quick Reply: Air Fuel Ratio? 12.4 to 1 too rich?
