Leaking steering gearbox
Old 04-20-2014, 11:53 PM
USMC1371
Cruising
USMC1371's Avatar
Default Leaking steering gearbox
My 73 vette steering gearbox leaks out the top. Is there a way to stop leak or should I replace it?
Old 04-21-2014, 05:16 AM
stingraymax
stingraymax's Avatar
Is this a new box ?
I believe that it is possible to leak some grease out of these boxes, but more knowledgeable people will probably jump in here ...
Old 04-21-2014, 06:27 AM
USMC1371
Cruising
USMC1371's Avatar
No, it's not a new box
Old 04-21-2014, 12:09 PM
C376FL
C376FL's Avatar
I can't help with problem. Just wanted to say another jar- head, I assume 1371 is MOS ( combat engineer ) Semper Fi.
Old 04-21-2014, 01:05 PM
USMC1371
Cruising
USMC1371's Avatar
Semper Fi! Yes it is Combat Engineer.
Old 04-21-2014, 02:11 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi USMC,
There is a readily available gasket for the top plate on the steering box if that's where the box is leaking.
Regards,
Alan
Old 04-21-2014, 09:18 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Leaking gear boxes can be attributed to a couple of things. A bad gasket, bad bushing or seal... but it can also be cause by someone putting oil in the box instead of grease. Even more common is the screet (spelling) from the grease. In humid area's or in cases where a car has been sitting a long time you can get a watery buildup in the grease and this can leak out too.
We make a tool for putting grease in the box the easy way. http://willcoxcorvette.com/product_i...ducts_id=27653
Usually when you pump grease in, the watery solution will come out.... and stop leaking on your floor.
Willcox
To Leaking steering gearbox
Quick Reply: Leaking steering gearbox
