Originally Posted by bgoodmug
(Post 1588036887)
The answer to my problem, finally got Justin from AAA Sound & Security in Dothan, AL to troubleshoot the problem. The Chevy dealer in Enterprise was wrong with trying to sell me a new $900+ alternator, but I knew that.
From Justin at AAA, "We diagnosed and fixed the OEM Bose amplifier. Amazing what a little piece of flux can do to compromise your audio system." 2 hours of labor. Said it probably was that way from the beginning, so a mfg issue? I've also experienced the same problem, radio off, engine off with a hum in the passenger large speaker. Thanks |
More stereo problems, similar but different.
I get static from the left front speaker at different volume levels just from opening the door.When I crank up I sometimes get a real blast from the same speaker. Car running or not running, radio on or off, I get some kind of noises 99% of the time. A least a low level static when driving. Sometimes barely audible, others quite noticeable but not affected by the radio volume. Anybody ? |
Guild, wish I could help more
Originally Posted by Guild
(Post 1588050879)
Sounds great, please expand on exactly what was found, was it soldering flux and where exactly?
(Post 1588053983)
I didn't do it so I can't provide the details you are looking for. I think they may have found it sort of by chance. They thought it was the Power Amp so they took it apart and say this 'dirty spot' on the circuit board inside the Power Amp. There are other possibilities that cause this & solutions but this apparently was mine.
The noise came back early 2016. I took out the radio again, re-seated the connectors and wire tied the cables under and behind the radio to keep them up off the chassis basically suspending the cables in the air. This seems to be where the interference is coming from and once again, the noise is gone and hasn't come back. |
(Post 1588053983)
FWIW, I ran into a similar thing on my wife's Infiniti FX35 the first week she had it. An intermittent buzzing from the rear speakers, didn't matter if the radio was on or off or if the car was running, but the ignition had to be on. Turned out that the speakers were picking up interference from the harness for the power tailgate of all things. The solution was to insulate the offending harnesses (double wrap with tape) and move them away from the speaker harnesses.
Apparently it was a common problem for FX35s, the dealer service dept knew exactly what it was when I took it in. Here's a link to the factory TSB: http://x.infinitihelp.com/forum/loca...id=379&id=1486 I know it's a completely different vehicle, but this interference from another electrical harness may be the same cause of some of the mysterious speaker noises described above, in which case some electrical tape was an easy and effective fix. Or maybe not :crazy: |
Originally Posted by wjnjr
(Post 1590179335)
True, and Corvettes don't have power tailgates either. The point was that in this case the noise was caused by the speaker harness running parallel to, and in contact with, another electrical harness. Easy enough to check and correct with the door panel off.
Just a guess really, hope anyone who fixes a speaker noise will post their solution :cheers: |
(Post 1590179325)
Actually the noise came back. The next solution was to put in a new line filter. Apparently certain power surges will blow out these 12 volt filters. I'm on my 3rd one now but it still filters 90 plus percent of the whine.
Originally Posted by Boomer111
(Post 1580843296)
Keep the radio off and put in a CD.
My radio is rarely on. Frustrating problem indeed. |
2007 Z06 with pioneer head unit/focal speakers. Same issue with tweeter behind driver seat increases whining with rpm. Bumps set it off and stops when it feels like it. Makes me think it is a loose connection at the back of the head unit. I will start there and report back if I come up with a solution.
(Post 1588050879)
noise from speakers
(Post 1591527578)
If you read the thread I updated it to indicate it was most likely NOT the soldering flux on the Power amp circuit board. What is the actual cause is undetermined but it is eliminated by a Line filter between the Power Amp and the radio.
Somehow the speakers are storing a load even when the radio is off and releasing the noise when the car is started (car is always running when this happens). It does not seem to be RPM related, since it is usually when the car just starts up. My warranty is ready to expire, so worth noting if it is a manufacturing defect. |
Aftermarket amps need the RCA cables ran away from the power cable or really good shielding used or higher quality rca cables.
I have a buzzing that occurs in the driver side pillar but i have that issue in both my c5 and c6. Sounds like a speaker buzz but its not a speaker. Any other buzzing is a bad ground location. Use a bigger ground cable or better ground. Could be a problem in the fuse box if it only happens after time and heat expanding the fuse block panel. |
1 Attachment(s)
Originally Posted by mmcushm99
(Post 1590177028)
2007 with NAV same issue. Speaker in driver door is the source of the humming noise, you could put your hand on the speaker and feel the vibration. After working on this for awhile, replacing the air sensor, etc. I found that the root cause was the NAV radio. Hitting the dash by the air sensor could make the noise come and go. Also opening the display (to load a CD) and slightly pushing the door left or right would make the noise come and go. Pulled the radio, re-seated all the connections, haven't had the noise come back. Pretty simple fix from my perspective.
The noise came back early 2016. I took out the radio again, re-seated the connectors and wire tied the cables under and behind the radio to keep them up off the chassis basically suspending the cables in the air. This seems to be where the interference is coming from and once again, the noise is gone and hasn't come back. Attaching a video of the humming noise. Radio is off, engine is off and the car is in accessory mode. Hitting the side of the radio will make the noise come and go. Happens on the road when hitting a bump. |
Good, at least you found the issue.
Ya poor solder joints and messy flux can be a problem. Have lots of experience with this in CB radios, amps and coax. |
