Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Old 02-23-2009, 01:45 PM   #1
Sparo2
CF Senior Member
Default List your L92/LS2 heads & cam combo here.
Hey guys.
Like others here I'm looking into adding a L92/L76 package to my LS2 and i would like to see some proven combos.
Please list your L92/L76 heads & cam combo or heads only combo here. Don't forget to list what cam you went with and other supporting mods. Also, don't forget to list your RWHP/RWTQ if you have it.
Thanks in advance.
Sparo2 is offline   Reply With Quote
Old 02-23-2009, 04:49 PM   #2
Fore58
CF Senior Member
Fore58's Avatar
05 Z51 Mn6: L92/L76 combo stock heads and gasket .020 milled, ported intake/tb, 224/228 114 LSA cam, Melrose 1 7/8" headers, VaraRam, 440 rwhp/405 rwtq. To note, the ported intake did not produce any further hp just 5 more on the torque....although the throttle response seemed to improve. Also, there was no fly-cutting on the pistons....enough clearance with this setup. Not track action as of yet.
Later, I may try the .040 cometic gasket for higher compression.
Fore58 is offline   Reply With Quote
Old 02-23-2009, 05:41 PM   #3
Craigster05
CF Senior Member
St. Jude Donor '07-'08-'09-'11-'12
Craigster05's Avatar
L92/L76 Setup Full Details
Craigster05 is offline   Reply With Quote
Old 02-24-2009, 12:47 AM   #4
Sparo2
CF Senior Member
Great info. Keep them coming guys.
Old 02-24-2009, 12:51 AM   #5
thomas walters
CF Senior Member
Support Corvetteforum!
thomas walters's Avatar
mods in sig
__________________
LS2 408 stroker; Manley internals; F1A Procharger; DP Flip Drive; 3.9" pulley- 8 rib; Katech LS9 clutch; Ported L92 heads; LT 1 7/8 headers w/ B&B Mild to Wild exhaust; Alky Control meth; Aeromotive A1000 fuel system; Pfadt coil-overs; F/R Z-06 sway bars; RPM Level 5 T56 trans and Level 5 Z06 diff; DTE diff brace; 4.10 gears; Wilwood BBK; Nitto NT05R rear and Michellin Pilot Super Sport front on WCC 946 wheels; 880 RWHP and 840 RWTQ on 91 octane; Build by Top Flight Corvette & Tune by RPM.
thomas walters is offline   Reply With Quote
Old 02-24-2009, 06:43 AM   #6
Sik Six
CF Senior Member
Sik Six's Avatar
Send a message via Yahoo to Sik Six
05 z51 mn6. L92/L76 heads/intake milled, 228/232 .598 .608 113lsa cam, 3.90 gears, Long tubes, B&B bullets, cai, underdrive pulley, ported tb..... 454rwhp/405rwtq through the 3.90 gears.
Sik Six is offline   Reply With Quote
Old 02-24-2009, 09:16 PM   #7
pharmd
Junior Member
AI CNC 243's, Custom grind cam, Kooks 1 3/4" catless Y, cutout, pulley, efan, CAI, 3200 stall, tune...AWD, 5000lb...low 12's...based on ET vs weight...its making some power (no AWD dyno's near).
Idle Clip cutout closed/then open
pharmd is offline   Reply With Quote
Old 02-24-2009, 10:04 PM   #8
kaislick
CF Senior Member
l92/l76, milled .025 and thin cometic gasket (no fly cut necessary) ported tb and intake (corey harris), 224/228 114 lsa 581 lift, arh 1 3/4, yella terra rockers, 4.10 rear. 445rwhp, 412 rwtq thru shorter tires - toyo r888 295/30/19
kaislick is offline   Reply With Quote
Old 02-28-2009, 06:58 PM   #9
vettecop1125
CF Senior Member
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
vettecop1125's Avatar
I had DTE do the L92/L76 upgrade to my 07 M6. Along with the heads/cam, I added Dynatech headers, K&N cai, Corsa sports, and underdrive pulley. I went from 353/357 stock to 460/432. The car had 450 miles on it when it underwent the surgery. I don't know the cam specs, but it's a small one - maybe a 3 out of 10 in size. I wanted reliability and driveability over numbers. It is absolutely perfect for me.
vettecop1125 is offline   Reply With Quote
Old 03-01-2009, 05:22 AM   #10
SpinMonster
SpinMonster's Avatar
Send a message via AIM to SpinMonster
L92/L76
L76 Intake is ported.
TB is ported.
UD pulley
Cam: 228/232 XER 114 LSA
Hardened pushrods
11.2:1 compression
Heads cleaned up on exhaust side for better I/E flow ratio
LG headers w/cats....a clear TQ gain with these heads
4.10's
Fidanza Al flywheel/LS7 clutch
Royal purple fluids
160 t-stat
40lb injectors
100mm MAF
Cartek /breather/catch can (no oil return in intake path makes octane higher and allows more timing)
471rwhp/433rwtq through 4.10's w 228 cam
SpinMonster is offline   Reply With Quote
Old 03-01-2009, 05:25 AM   #11
debo
CF Senior Member
debo's Avatar
Nice setups....
debo is offline   Reply With Quote
Reload this Page List your L92/LS2 heads & cam combo here.
Tags
020, cam, heads, l92, list, ls2, milled
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
