C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LS7 aluminum intake
Old 02-14-2012, 02:29 PM
Randy@RaginRacin
Supporting Vendor
Randy@RaginRacin's Avatar
Default LS7 aluminum intake
Just got one of these in to try. Thought I would share a few pics. This will be a nice add on for F/I or large cams that like the higher rpm's.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x577 and weights 139KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x577 and weights 136KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x577 and weights 167KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x577 and weights 97KB.
__________________
Randy Leger
337-278-8397
sales@raginracin.com
http://www.raginracin.com
Old 02-14-2012, 02:57 PM
SinisterC6
SinisterC6's Avatar
Do want, I'm sure it's not cheap tho...
Old 02-14-2012, 06:56 PM
LB
LB's Avatar
Who Makes, How Much ?
Old 02-14-2012, 07:14 PM
pamperedcar1
pamperedcar1's Avatar
$$$$ how much?who?when? And most of all any gains in hp or torque?
Old 02-14-2012, 07:20 PM
filmjay
filmjay's Avatar
St. Jude Donor '10
I've seen that, but not one installed. Good to know it fits under the stock hood.
Old 02-15-2012, 12:48 AM
pamperedcar1
Yeah I think it was at sema
Old 02-15-2012, 09:46 AM
Randy@RaginRacin
Supporting Vendor
$2500 is the cost. It comes with fuel rails.
Old 02-15-2012, 09:51 AM
Randy@RaginRacin
Supporting Vendor
I can get one for you. Made per order. Normally a couple of weeks. I do not expect this intake to be usefull on a stock or small cammed motor. It will have all its benifits at high RPM's and forced induction.
My first test will be on a forged ls7 with ysi.
The intake is 2500 with fuel rails and can be made for stock tb or 102.
__________________
RAGIN RACIN
Randy Leger
337-278-8397
Old 02-15-2012, 11:19 AM
SinisterC6
SinisterC6's Avatar
What are the gains over a ported fast 102?
Old 02-15-2012, 05:23 PM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,091 Likes on 659 Posts
I would love to see before and after results posted on the YSI car.
Old 02-15-2012, 05:51 PM
pamperedcar1
I have some concerns that meth my pool in the valley but really want to see some test results
Old 02-15-2012, 07:19 PM
LB
LB's Avatar
I happen to have a YSi ... Will you dyno compare this to the stock intake or fast ? I understand that the tune will change, but supercharger will show true results of using the same pully.
Old 02-15-2012, 07:24 PM
LB
LB's Avatar
If these are made to order, can they stagger the intake runner length front to back ?
Old 02-19-2012, 01:39 PM
chuntington101
chuntington101's Avatar
LB there is no need. THats probably just to show the different intake trupet lengths you can opt for. i have seen staggered trupet lengths (4 pot inter 2 cylinders longer than the outer two) and there was an improvement in power and torque under the curve for a small reduction in top ens.
As for the OP, i think the intake runners are two short. Also be nice to know what volume the plenum is. Again looks on the small side but could be wrong.
Think you will still see the rear cylinfers running lean as they get all the air. be intresing to see if they could increase the volume of the plenum but seperate the two banks of. THen feed each back from a centeral channel through a narrow slit. I have seen this used to good effect on 500++bhp 2.0ltr engines. can really help evan out the air flow across the cylinders.
Chris.
Old 06-21-2012, 05:17 PM
Randy@RaginRacin
Supporting Vendor
Finally got some numbers!! NA forged z06 with mast heads and 2" AR headers running a Punisher cam on E85. Results are a comparison to a fast 102. As you can seen the Fast out performs the sheet metal intake all the way to 6200 rpm's but for those of you with power to spare down low or if you are a high rpm racer this is the intake for you. 47 more HP and 34 lbs of torque on top. What a punch!!
This image has been resized. Click this bar to view the full image. The original image is sized 1024x606 and weights 105KB.
__________________
Randy Leger
337-278-8397
Old 06-21-2012, 05:22 PM
Drewstein
Drewstein's Avatar
Looks like the FAST kicked it's *** to me.
Lets see it with FI.
Old 06-21-2012, 05:39 PM
Randy@RaginRacin
Supporting Vendor
For 95% of us I would agree. But not if you are doing some 60 to 160 racing!!
To LS7 aluminum intake
Old 06-21-2012, 08:42 PM
slow ride
slow ride's Avatar
Really need a solid roller or really light valvetrain to take advantage of it.
Old 06-22-2012, 12:38 PM
0Jeremy@HOB
Former Vendor
Jeremy@HOB's Avatar
It's the short runner on an n/a motor that makes it look like it got its *** kicked. The real story will be on a boosted application.
Old 06-22-2012, 01:29 PM
Drewstein
Drewstein's Avatar
That's exactly what I'm excited to see.
Quick Reply: LS7 aluminum intake
