C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Disabling Onstar...
Old 04-03-2009, 01:53 AM
427 C6Z
427 C6Z's Avatar
Default Disabling Onstar...
Anyone know how to "easily" disable Onstar? Is it as easy as removing a fuse?
Old 04-03-2009, 11:12 AM
Landru
Landru's Avatar
Received 1,047 Likes on 821 Posts
If there is a fuse, yes, I'd say that'd do the trick.
Absent a fuse, though?
See that little black rectangular box at the right-center-top of the windshield? Find the wire feed to it, use a small wire clipper to *interrupt* communications. Permanently.
Old 04-03-2009, 12:21 PM
427 C6Z
427 C6Z's Avatar
I guess I was hoping not to have to "permanently" clip something. My hope would be to simply do so sort of "easy" disconnect allowing me to reconnect at a future time should I so desire.
Relative to removing a fuse, I'd want to know what else, if anything, that I might be powering down with the fuse out. Anyone know for sure? Anyone know which fuse to remove?
As always, I appreciate your collective insight...
Old 04-03-2009, 12:54 PM
6spdC6
6spdC6's Avatar
Location: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
This subject has come up many times. If the search feature is working there will be tons of info on here about how to kill onstar the right way.
Old 04-03-2009, 01:35 PM
427 C6Z
427 C6Z's Avatar
Actually I have done this and still find myself at a bit of loss; perhaps I just haven't found the "right" thread. I did find a lot of "I believe" information but wasn't able to find a definitive or concrete "how to." I'm hoping that it is in fact as simple as removing a fuse I just need to know which one and what else, if anything, I'd be powering down with the fuse removed; anyone know "for sure?"
Old 04-03-2009, 02:14 PM
Dreamin
Dreamin's Avatar
Short answer:
* Remove fuse (in-car fuse panel)
* Unplug J1, J2, J3 and antenna connectors from onstar module under passenger seat
* Leave J4 connector on onstar module plugged in!
Long answer:
See post #18 here: http://forums.corvetteforum.com/c6-t...r-removal.html
And then start reading from post #130 onward in the thread referenced in the above post.
Note that the posts above are for a C6... where the onstar module is in the rear of the car; on a Z06 it's under the passenger seat.
Old 04-03-2009, 03:26 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
I know you can't turn back the clock, but the best way to disable onstar is to not activate the thing in the first place. That's what I did. Did you know they can listen to you when you're driving?
Old 04-03-2009, 04:25 PM
RichieRichZ06
Supporting Vendor
Support Corvetteforum!
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
...and they know what you had for lunch.
Old 04-03-2009, 04:34 PM
Landru
Landru's Avatar
Sound Richie, not smell.
Old 04-03-2009, 04:36 PM
Landru
Landru's Avatar
I know my friend, just teasing.
Wanted to bump your thread TTT so others might see it & respond; and, a few have.
Old 04-03-2009, 05:13 PM
383vett
383vett's Avatar
I wouldn't be too sure. They know eveeeerrrrrryyyyything about you and your car, what you're wearing, where you've gone, who you're seeing, what you're doing tomorrow......
Old 04-04-2009, 10:03 AM
Landru
Landru's Avatar
Guess I've poor hindsight.
Ahhhhh, l'il helpers of zerO's for his civilian army.
Y'know I realize there's huge potential for the abuse of OnStar, and if and/or when the day comes?
I *will* get out the wire clippers and pull the plug.
Old 04-04-2009, 10:15 AM
DaOtherOne
DaOtherOne's Avatar
The dealer verifies that the Onstar system is working during the Pre-Delivery Inspection (PDI).
Old 04-04-2009, 01:29 PM
RUBYREDVET
RUBYREDVET's Avatar
Don't renew after the year is up. An aluminum turban helps too.
Old 04-04-2009, 01:35 PM
383vett
383vett's Avatar
I thought after taking delivery of the car, the onstar is activated. Otherwise all the GM vehicles not yet sold on the lots would have working onstars. Nonetheless, mine has never worked and never been activated. Thanks dealer!
Old 04-04-2009, 01:36 PM
383vett
383vett's Avatar
Do you put this around the onstar antenna?
Old 04-04-2009, 01:39 PM
RUBYREDVET
RUBYREDVET's Avatar
Never tried that, I just wear it on my head.
To Disabling Onstar...
Old 04-04-2009, 01:45 PM
383vett
383vett's Avatar
Do you cut out holes for your eyes or do you just "feel" the road.
Old 04-04-2009, 02:15 PM
DaOtherOne
DaOtherOne's Avatar
The cars come with the first year free.
It's activated in your name based on the Customer Delivery Record (CDR) that is generated by the dealer sales process.
Old 04-04-2009, 02:17 PM
RUBYREDVET
RUBYREDVET's Avatar
Now I think you're makin fun of me. Of course I have to cut holes for my eyes. I do wrap 3 layers though, just in case. And I don't buy the 'cheap' stuff.
Quick Reply: [Z06] Disabling Onstar...
