Z51 glove box code
Old 12-25-2012, 11:27 AM
Mach2
Mach2's Avatar
Default Z51 glove box code
Looking to buy an 08-10 C6 Coupe after the 1st of the year and we return to Henderson, NV. I've searched "Z51 glove box code", "Z51 code", Z51 and a few other titles and have not found it. I've seen posted here a link to the 3 digit codes on the tag inside the glove box. I know the Z51 has the slightly larger diameter rotors that are drilled, but some have added the Z51 brake package to their non Z51 C6 Coupes. I just want to make sure the C6 came with the Z51 package, since there's other things suspension related to this package besides the larger/drilled rotors.
Did 2010 C6 Coupes have the Z51 option or did that option go away with the 2010 year?
TIA.
Old 12-25-2012, 11:31 AM
RicK T
RicK T's Avatar
No Z51 in 2010. The GS got the Z51 parts in 2010.
Old 12-25-2012, 11:57 AM
boraxman
boraxman's Avatar
^^^^True that otherwise it will say on the glovebox sticker
Old 12-25-2012, 12:05 PM
C6FirstVette
C6FirstVette's Avatar
Z51, besides brake and suspension goodies, includes different tranny and extra coolers for tranny and engine fluids.
Old 12-25-2012, 12:06 PM
Mach2
Mach2's Avatar
Thanks folks.
Old 12-25-2012, 01:52 PM
CO Lightfoot
CO Lightfoot's Avatar
FYI, other year-to-year changes for '09 & '10:
http://forums.corvetteforum.com/1570645504-post5.html
Old 12-25-2012, 03:52 PM
Mach2
Mach2's Avatar
Thanks CO Lightfoot.
Old 12-25-2012, 08:00 PM
bud miller
bud miller's Avatar
here is my glove box on my 09 z51.."CSC" coupe..
Old 12-25-2012, 09:10 PM
Gearhead Jim
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
Someone said that the GS cars are also marked Z51 on the glove box label, because they have some of the previous Z51 components. Can one of you GS guys, preferably without F55, take a look at your label and tell us what's there?
Thanks.
Old 12-25-2012, 09:15 PM
CaryBob
CaryBob's Avatar
Thanks.
Yes. My 2012 GS has the Z51 code on the glove box sticker. I do not have F55. Wish I did.
Old 12-25-2012, 09:26 PM
RicK T
RicK T's Avatar
Thanks.
Here's a 2011 GS label:
Old 12-25-2012, 10:24 PM
ls1121
ls1121's Avatar
St. Jude Donor '14-'15
I have an 2008 Z51, what is different about my Tranny? I have an A6.
Old 12-25-2012, 10:44 PM
Gearhead Jim
St. Jude Donor '13
Thanks.
Thanks!
Old 12-25-2012, 10:47 PM
Gearhead Jim
St. Jude Donor '13
With the A6, a 2008-09 Z51 will have an identical A6 transmission but the rear axle ratio gets changed from 2.54 to 2.73. The 2.73 was also available as a stand-alone option, but I haven't seen many cars set up that way.
Old 12-25-2012, 10:59 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
Z51 and GS both have the FE3 suspension. You need to see the FE3 code on the sticker on every Z51 or GS.
Bill
Old 12-25-2012, 11:40 PM
ls1121
ls1121's Avatar
Bill
My car has the FE3 but I don't see that description for the option anywhere.
Old 12-26-2012, 02:41 AM
ZR1 136
ZR1 136's Avatar
Is there a list of what all the codes mean? I know a few of the codes because I ordered the GS. Such as the build code and a few of the others.
To Z51 glove box code
Old 12-26-2012, 06:50 AM
C6FirstVette
Clarify... the MN6 with Z51 is a close ratio tranny... no changes if automatics
Old 12-26-2012, 08:46 AM
tim414
tim414's Avatar
St. Jude Donor '12
2009 was last year for Z51 option code. It became Z52 in GS I think.
Old 12-26-2012, 08:52 AM
SouthBaySurfer
SouthBaySurfer's Avatar
I've got one, Jim; 2008 coupe, non-z51, A6, performance axle(GU2).
Quick Reply: Z51 glove box code
