Bluetooth Kit for 2005-13 C6
Old 02-20-2013, 09:25 AM
corvettej
Support Corvetteforum!
corvettej's Avatar
St. Jude Donor '13-'14-'15-'16-'17-‘18-‘19-'20-'21-'22-'23-'24
Default Bluetooth Kit for 2005-13 C6
Well I just received my hopefully solution to having bluetooth intergrated into my 07 corvette. I received ISimple ISGM655 yesterday and will try to install myself when the weather warm up some because we know cold and plastic doesn't work together, its easy for tabs and parts to break or break off. Here are some pictures of the kit.
Drill Bit 1/4
Wrench 7mm
Extension 3/8 4"
Socket 10mm
Ratchet 3/8
Screwdriver Phillip & Flat Tip
Allen Set (MGW Shifter)
Ratchet 1/4
Socket 7mm
extension 1/4 4"
Tape 3M Industrial Strength
Safety Glasses
Flashlight
Safety is number one, you assumes all risk for your action, this is how I did it. Handbrake should be set already. Take your time.
Important: Before you disconnect the battery make sure the radio is set for FM not XM then disconnect the battery on the positive side.
This install is for GM navigational radio, open the console and remove the four phillip screw to the console top, once remove replace the screw in the top and put aside.
Remove the two plastic knock off or cover to remove two screws using 1/4 ratchet, extension and 7mm socket.
Pull straight up on the bottom edge of the hand brake boot to get it loose. You will see two 7mm screws, go ahead and remove, then gentley pull up on both side and it should start to come loose, the part of the console on the passenger side will come loose from the main piece.
Remove the shifter ****, unplug the Hazard switch, the cigarette lighter, heater switches and the Aux power then you should be able to turn the console sideway and lay to the side with traction control still hook up.
Using the 1/4 ratchet with extension and 7mm socket to remove the screws from the air condition control first then pull it forward.
Now remove the screws from the radio, then with a slight pull on the radio it should come loose.
This is what you should see.
With the new cable in hand(a figure of speech) go ahead and unplug the two big plugs (The blue plug and the black plug) and set aside. Plug in the cable that came in the kit to the corresponding plugs. Now this free spot in the back of the firewall is where I mounted the gateway from the kit.
Apply the 3M tape to the Gateway.
Here is a closeup of the spot
If you use this location this is how it should be mounted if you mount it straight up the DIN plug will keep falling out so it shall be sideway like I have it. Make sure you put usb plug through the usb bracket before you put the radio back in or you will be sorry like me.
Putting it back together. Radio first, no screws, we need to make sure it work.
Air condition next, no screws.
Reconnect the battery. The radio should come on in FM like in the photo.
Then press XM tab and your screen should say "DEV INIT".
and "NO PHONE"
Go to your cell phone, make bluetooth is turn on.
Do the pairing per your cell phone instruction.
You might see this screen(STREAMING).
or this screen saying ready. When the radio had BT on the screen press and hold button 6, it will label it BT as in the picture. You are now Bluetooth ready to make a call. Button 1 answer or ends a call, button 3 setting make sure the microphone volume is set between 8 and 10.
Here is where I put my reset button, be careful using the 1/4 drill bit and drill, make sure no wire are where you are drilling and take your time the rewards will pay off.
When I found that usb bracket I will install it on the driver side above my Escort Live where it is within reach. This will get you started.
Old 02-20-2013, 09:59 AM
0Double D Mods
Former Vendor
Double D Mods's Avatar
St. Jude Donor '12-'13
Install is pretty simple
one correction
The kit will only work with 2005-2010 as the radios slightly changed in 2011-13 for wiring only.
Old 02-20-2013, 10:24 AM
corvettej
corvettej's Avatar
Not a issue, I was just reading off the back of the box where it said 05-13 but that's fine I think 10 and up already have bluetooth.
Old 02-20-2013, 10:29 AM
Norm66
Norm66's Avatar
St. Jude Donor '08-'09-'10
Do you have to pull the radio out to install it?
one correction
Old 02-20-2013, 11:03 AM
Arsonone
Cruising
Arsonone's Avatar
Is your C6 equipped with SAT radio? My 07 C6 is non Nav, and non Bose. I think your instructions will tell you to go to GM and have them activate the inactive XM port. After looking at me like I was crazy, they put the computer on my car. They stated that there was no option on the menu to do what I wanted. If your situation is the same as mine, I am very interested to know if your install it successful. Please post your results, Thanks
Old 02-20-2013, 11:17 AM
0Double D Mods
Former Vendor
yes
its pretty easy to do on a C6
4 T15 torx screws on console lid
2 7mm next to cig lighter in console
2 7mm under ebrake boot
disconnect the hazzard connector
disconnect the cig lighter in ash tray then in console
disconnect traction control
disconnect heated seats if equiped
Old 02-20-2013, 01:41 PM
Arsonone
Cruising
Arsonone's Avatar
Has any forum member ever had a inactive XM port activated by a GM dealer?
Old 02-20-2013, 02:01 PM
0Double D Mods
Former Vendor
look on radio and see if there is a button that says BAND
if so then your good to go and they can program it
0Double D Mods
Former Vendor
yes we have come across a couple people who have not had theirs activates
Old 02-20-2013, 02:15 PM
BWF07
BWF07's Avatar
St. Jude Donor '11
Oldtimer
I have an '07 3LT with but instead of the US9 radio, I have the U3U option. Also is this system for the Iphone only?
Old 02-20-2013, 02:20 PM
0Double D Mods
Former Vendor
link to purchase
http://shop.doubledmods.com/searchqu...ywords=isgm655
Description:
iSimple Connect is a premium factory radio interface for Android, iPod, iPhone, or iPad,
and other smartphones for select 2003-2012, General Motors vehicles.
*WILL ONLY WORK FOR 2005-2010 CORVETTES*
Included:
(1) iSimple ConnectTM module with built-in Bluetooth
(1) Vehicle specific harness
(1) Hands-free microphone
(1) 6 foot USB extension cable with dash mount bracket
(1) Installation manual
(1) Rearview mirror hang tag for customer (welcome card)
(1) Interface reset switch
Functions:
- Full control for iPhone: Wirelessly (Bluetooth) or Wired (using customer’s Apple USB cable)
- Basic control for Android: Wirelessly (Bluetooth)
- USB Thumb-drive support: upto 32GB and upto 8,000 MP3 files
- 2.1 Amp USB connection for charging of smartphones, tablets, and media players
- Android audio streaming and wireless track control through Bluetooth connection
- Built-in Bluetooth for hands-free calling (HFP) and audio streaming (A2DP)
- Song text (metadata) on factory radio
- Auxiliary audio input (3.5mm or RCA)
- Expandable: Connect an ISSR11 cable and add an SCC1 Satellite tuner
Connect an ISSR12 cable and add an SXV100 or SXV200* Satellite tuner
(Sat tuners, and ISSR11, and ISSR12 cables all sold separately.)
NOTE:
Compatibility Notes
Vehicle MUST be either equipped with, or have the ability to support Satellite Radio
Radio must have a "Band" or "XM" button to be compatible
Not compatible in vehicles equipped with "Monsoon" system or any other "signal sensing" amplifier.
When using the PGHGM5 harness: Some radios may have an inactive satellite radio port if not equipped with a factory satellite radio tuner. Please see a dealer for activation of this port to enable the interface
Old 02-20-2013, 02:56 PM
not08crmanymore
not08crmanymore's Avatar
I plug my iphone into the aux hole and instant bluetooth..
Old 02-20-2013, 04:53 PM
Tonylmiller
Tonylmiller's Avatar
Really? that seems strange, to plug in a wire to get a wireless connection.
Old 02-20-2013, 05:27 PM
sportcruiser
sportcruiser's Avatar
What an Auxhole!
Seriously, it works and the sound quality beats Bluetooth.
Old 02-20-2013, 05:37 PM
andy82
andy82's Avatar
2017 C7 of Year Finalist
Interested & Subscribed!
Old 02-20-2013, 11:30 PM
6893Vette
6893Vette's Avatar
I'm interested in hearing about your install. I have a 2005 and put in an aux jack that is connected to sat but would like Bluetooth.
Old 02-21-2013, 03:06 AM
gunnerjuju
gunnerjuju's Avatar
Just purchased the same kit. Where do you plan to put the aux,USB and microphone? I'm thinking of putting USB in glove box (gets too hot in center console and might over heat iPod or phone) aux some where on the dash maybe side of radio next to passengers side or center console. microphone on A pillar.
To Bluetooth Kit for 2005-13 C6
Old 02-21-2013, 09:24 AM
corvettej
corvettej's Avatar
Well its a sunny day here in Augusta, GA, so I'm going to attempt this install. My 07 has an 08 navigation unit, and its a 6 speed. My intention are to take some pictures and tell you the mistakes I made so your installation will be pain free. Later
Old 02-21-2013, 09:48 AM
not08crmanymore
What an Auxhole!
Old 02-21-2013, 12:38 PM
corvettej
corvettej's Avatar
Well good news, it works. Had to call Tech Support to get it from streaming to BT, made some calls and receives some, you don't have to touch the phone seem like it can be control from the navigation screen with the presets. Will upload some pictures after I figure out where to put the reset button, the usb port and the microphone probadly in the A pillar with the mic from the navigation. Back to the drawing board.
Quick Reply: Bluetooth Kit for 2005-13 C6
