Where is the reverse lockout solenoid located?
Old 09-07-2013, 10:59 PM
Cosmo Kramer
Cosmo Kramer's Avatar
Default Where is the reverse lockout solenoid located?
Had the common problem of my reverse lockout solenoid not working. So, I ordered a new solenoid (part # 19178634) from Gene. From what I've read, the solenoid is located on the passenger side of the tranny. Well, I removed what I thought was the solenoid only to find that the old part required a 23mm wrench and the new one is a 27mm. Additionally, the threaded portion of the new solenoid is much larger than the old one. Did I remove something other than the reverse lockout solenoid? If so, what did I remove and where is the reverse lockout solenoid located?
Pictures would be very helpful. Thanks.
Old 09-07-2013, 11:37 PM
65GGvert
65GGvert's Avatar
Received 3,217 Likes on 2,301 Posts
You're right, pictures would be very helpful.
Old 09-08-2013, 01:31 AM
COS C5
Navigator
COS C5's Avatar
Default lockout
Here's one link
http://forums.corvetteforum.com/c5-t...-solenoid.html
Easier to remove the assembly, once the single bolt is removed it pulls out to the right side. when installing be sure the trans is in N so it can be pushed back in all the way against the housing. I just changed mine. nothing like being under a Corvette, hugging the trans! There was another post with much better picture but I'm having difficulty finding it now. It's really about a 30 minute job,
Old 09-08-2013, 09:38 PM
Cosmo Kramer
Now I know why there are no clear pictures of the reverse lock out solenoid - it's on top of the tranny and a real B*TCH to get at. Knowing what I know now, I would have paid the dealer to install it. Getting at the bolt that holds the solenoid is done by feel - you cannot see the bolt and it's VERY tight up there. I consider myself to be mechanically inclined (I rebuilt the engine on my '70 350 and put a new clutch in my son's WRX.) Also, because I did not get the solenoid in perfectly flat, the car would not go into 5th gear. As such, I had to remove the solenoid and make sure it was seated correctly.
Old 09-09-2013, 12:22 AM
COS C5
Navigator
COS C5's Avatar
It sounds like after a false start you got it to function correctly.
Old 09-09-2013, 09:20 AM
Patches
Support Corvetteforum!
Patches's Avatar
Yes - is a pain to get to with the tranny in place. Here are a few pics.
Old 09-09-2013, 10:24 AM
slvr bulit
slvr bulit's Avatar
Nice pictures Patches! Here's what mine looked liked when it came out for a clutch job last winter.
Old 09-09-2013, 03:13 PM
Cosmo Kramer
Patches......Great pictures of the solenoid. With the tranny out, I hope you replaced the solenoid.
To Where is the reverse lockout solenoid located?
Quick Reply: Where is the reverse lockout solenoid located?
