HELP!...c5 coolant surge problem
Old 09-07-2013, 02:03 PM
Phantuhhm
Navigator
Phantuhhm's Avatar
Default HELP!...c5 coolant surge problem
So today I got home from the store when I turned my car off I heard a hissing sound, when I popped the hood the noise was coming from the coolant surge. The surge was really hot and I could see it steaming the main thing that was hissing was the tube connected to the coolant surge on the left. Also it looks like the tank was squirting out coolant all over the engine.. Any idea what's wrong? Do I need to drain and replace coolant? Overfill? Please help...
Old 09-07-2013, 02:48 PM
Paul 75 L82
Paul 75 L82's Avatar
What was the temp when you turned it off? Sounds like it has a leak, that's where I would look first.
Old 09-07-2013, 04:08 PM
racebum
racebum's Avatar
if you recently filled coolant and overfilled the system that's one thing
however
it sounds like you're boiling the coolant. remember, without pressure the coolant will boil at 212deg which is not hard to hit in a c5
the fill cap is a potential suspect if you aren't leaking coolant anywhere
ac delco replacement caps are also under 10 bucks
Old 09-07-2013, 05:45 PM
racebum
racebum's Avatar
Originally Posted by 8VETTE7
This is true if the coolant is water only. However the mixture in most cars is about 50% water and 50% anti-freeze (perhaps DexCool). A 50/50 mixture has a boil point of about 260 degrees F. without pressure if my memory is correct. So if his coolant is boiling he has a real problem.
I suspect that one of the plastic bungs on the surge tank is cracked where it attaches to the tank and that the system does not build a lot of pressure but rather pisses the coolant out the crack.
pressure is what allows water to surpass 212, not the dex cool. straight water is actually more effective at cooling than antifreeze. the reason we use antifreeze is because of the anti corrosion and obvious anti freezing part
To HELP!...c5 coolant surge problem
Quick Reply: HELP!...c5 coolant surge problem
