C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] *** The Official C6 Z06 DIY Thread ***UPDATED 08/25/13**
Old 09-11-2009, 01:02 AM
Dreamin
Dreamin's Avatar
Default *** The Official C6 Z06 DIY Thread ***UPDATED 08/25/13**
The purpose of this thread is to consolidate all of the DIY and How To's posted here in the C6 Z06 section.
C6Z06 FAQ (former sticky)http://forums.corvetteforum.com/c6-z...tions-faq.html
Please post your DIY procedures or links to DIY threads... only.
Clutch Pedal Issues http://forums.corvetteforum.com/c6-z...-and-cure.html
LS7 Broken rocker arm needle bearing issues http://forums.corvetteforum.com/c6-z...ngs-issue.html
I'll keep a table of contents in this post:
Post #2: Diff Fluid Change *Z06 Specific*
Post #2: Transmission Fluid Change *Z06 Specific*
Post #2: Changing Stock Air Intake Filter Element *Z06 Specific*
Post #2: Steering Wheel Replacement (or side-spoke cover replacement)
Post #2: Brembo Big Brake Kit Install
Post #2: Caravaggio Race Seat Install
Post #2: Accurate Oil Pressure Logging (aka checking for oil starvation)
Post #2: LPE High Capacity Oil Tank Installation
Post #3: Shock Removal & Replacement
Post #4: Oil Change
Post #4: Brembo BBK pad change
Post #5: Properly change the color of the interior accent LED
Post #6: Wheel Center Cap Painting
Post #7: Kenwood Navigation Install
Post #7: Factory Navigation Mod to change destination without stopping the car
Post #7: Disabling Onstar
Post #7: Muffler Mod-Improved Sound, Reduce Drone, Possible increase in Power
Post #7: Muffler-Exhaust Controller
Post #8: Paint Your Hoodliner
Post #9: XM receiver disconnect/removal
Post #10: Battery tender outlet/connection
Post #11: Removal of Visor Warning Label
Post #12: ZR1 Splitter Install
Post #13: Cabin Insulation
Post #14: C6 Z06 Torque Specs
Post #15: 'Rolling' Rear Fender
Post #16: Foglite Brake Duct fabrication
Post #17: Changing Brake Pads / Rotors on Stock Calipers
Post #18: Front Bearing Replacement
Post #19 Vararam Snake Charmer Air Intake & Ported throttle body install
Post #20 How to bleed clutch
Post #21 DIY LS7 Head swap
Post #25 Clutch Pedal Issue how to prevent/cure
Post #26 LS7 Broken Rocker Arm Needle Bearings Issue
Dreamin
Dreamin's Avatar
DIY - Diff Fluid Change *Z06 Specific*
DIY - Transmission Fluid Change *Z06 Specific*
DIY - Changing Stock Air Intake Filter Element *Z06 Specific*
DIY - Steering Wheel Replacement (or side-spoke cover replacement)
DIY – Brembo Big Brake Kit Install
DIY - Caravaggio Race Seat Install
DIY - Accurate Oil Pressure Logging (aka checking for oil starvation)
DIY - LPE High Capacity Oil Tank Installation
finnfjr (10-06-2018)
Old 09-11-2009, 01:06 AM
dvandentop
dvandentop's Avatar
DIY - SHOCK REMOVAL & REPLACEMENT
http://forums.corvetteforum.com/c6-z...tallation.html
Audthng (12-08-2015)
Old 09-11-2009, 01:15 AM
Dreamin
Dreamin's Avatar
DIY - Oil Change: http://forums.corvetteforum.com/c6-z...il-change.html
DIY - Brembo BBK pad change: http://forums.corvetteforum.com/c6-z...-pad-swap.html
Old 09-11-2009, 01:24 AM
CudjoeScott
Support Corvetteforum!
CudjoeScott's Avatar
St. Jude Donor '09-'10-'11-'12
DIY - Properly change the color of the interior accent LED (author DSteck): http://forums.corvetteforum.com/c6-z...ccent-led.html
Old 09-11-2009, 11:28 AM
qualitycare
qualitycare's Avatar
DIY - Wheel Center Cap Painting
http://forums.corvetteforum.com/c6-t...w-to-pics.html
Old 09-16-2009, 11:30 PM
donavonknight
donavonknight's Avatar
Default Diy
DIY-Kenwood Navigation Install
http://www.dfwcorvettes.com/dnx8120install.asp
DIY-Factory Navigation Mod to change destination without stopping the car
http://www.kawal.net/navigation.htm
DIY-Disabling Onstar
http://forums.corvetteforum.com/c6-z...ng-onstar.html
DIY-Muffler Mod-Improved Sound, Reduce Drone, Possible increase in Power
http://members.***.net/frank.patry/vette/z06muffmod.pdf
DIY-Muffler-Exhaust Controller
http://www.dfwcorvettes.com/DIYWirel...Controller.asp
Old 09-28-2009, 09:21 PM
xcutter
CF Senior Member
xcutter's Avatar
DIY - Paint Your Hoodliner Step by Step Instructions
DIY Paint Your Hoodliner Link
Old 09-29-2009, 10:35 AM
Solaris
Solaris's Avatar
DIY - Remove XM bands from the radio selector
Old 09-29-2009, 06:41 PM
Stage Runner
Stage Runner's Avatar
DIY - Battery tender outlet/connection
http://www.kawal.net/chargerplug.htm
SR
Old 11-18-2009, 01:04 PM
Ravine Speed
Ravine Speed's Avatar
Default DIY Removal of Visor Warning Label
I posted this a while ago, but it stil works! Get rid of those pesky warning labels!
http://forums.corvetteforum.com/c6-z...finitive+visor
Old 12-02-2009, 09:56 PM
Dreamin
Dreamin's Avatar
http://forums.corvetteforum.com/c6-z...ll-how-to.html
Old 02-22-2010, 10:35 PM
Dreamin
Dreamin's Avatar
The ultimate cabin insulation DIY:
http://forums.corvetteforum.com/c6-z...ct-begins.html
http://forums.corvetteforum.com/c6-z...ct-are-in.html
Old 03-17-2010, 01:22 AM
Dreamin
Dreamin's Avatar
David Farmer's C6 Z06 torque spec pdf: http://www.davidfarmerstuff.com/
Old 03-17-2010, 11:35 PM
Dreamin
Dreamin's Avatar
DIY - 'Rolling' Rear Fender: http://forums.corvetteforum.com/c6-z...r-rolling.html
Old 05-10-2010, 12:54 PM
Dreamin
Dreamin's Avatar
DIY - Foglite Brake Duct fabrication: http://forums.corvetteforum.com/c6-z...brication.html
Old 05-24-2010, 09:12 PM
Dreamin
Dreamin's Avatar
DIY - Changing Brake Pads / Rotors on Stock Calipers
Great pictures and writeup in these two threads:
http://forums.corvetteforum.com/c6-z...ng-rotors.html
http://forums.corvetteforum.com/c6-z...rake-pads.html
To *** The Official C6 Z06 DIY Thread ***UPDATED 08/25/13**
Old 09-24-2010, 01:27 AM
Dreamin
Dreamin's Avatar
DIY- Front Bearing Replacement
http://forums.corvetteforum.com/c6-z...-tutorial.html
Old 11-10-2011, 04:59 PM
MLFD5C6Z
MLFD5C6Z's Avatar
Vararam snake Charmer air intake & Ported intake & throttle body install:
http://forums.corvetteforum.com/c6-z...s-of-pics.html
Old 06-02-2012, 04:18 PM
Wulverine
Wulverine's Avatar
St. Jude Donor '15
How to correctly bleed the clutch system. Posted by BgBoost1 via instructions from Katech.
http://forums.corvetteforum.com/c6-z...lly-fixed.html
LTVN68 (03-28-2018)
Quick Reply: [Z06] *** The Official C6 Z06 DIY Thread ***UPDATED 08/25/13**
