C5 Ignition Switch Repair
#201
St. Jude Donor '06-'07
OK - checked all the fuses and they all get the correct power and they are all good.
The car only gave me one hard start problem a week ago, and never before that. When it happened, I had left it sitting for about 45 minutes after a 20 minute drive and came back to a no-start. After about 20 tries, it stumble-started, like I had a batch of bad gas. Once it stumbled through that, it ran fine. Came out the other day to take it for a ride, and got it to start after about 30 tries, but this time it fired up like nothing happened - no stumble. Today, nothing. It turns and turns no problem, but will not fire. Now I've done everything in this thread and nothing has changed. What's next?
Oh, and there are no codes whatsoever...
Also pulled plugs - light brown, all around .038 gap. Do I have a fuel pump issue?
#202
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you turn the ignition to ON/RUN,,, do you hear the fuel pump HUM for approx 5 -6 seconds and then stop???
Trying to isolate what would cause an engine to crank but not fire and run.
How are you reading the DTCs and are you reading them without turning the ignition OFF. When you have a NO START EVENT,, press reset to clear any message and read the DTCs....
Bill
Bill
#203
I do NOT hear the fuel pump run. The fuse to it is fine - seems odd that it would not be working, but maybe that's it? It has always been so much quieter than my old '99 that I don't even expect to hear the pump, but I suppose I should hear something.
The car spent all of it's life in Texas and has rarely seen the road here in Ohio. Every ground connection has been clean clean clean. I'm reading the DTC's with the key on ON and by manually scrolling through them using the gauge buttons. No Codes all the way through.
#204
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The fuel pump should be your very first area of concern.. Start there and let us know what you find. When you KEY ON,,,,,,,, it should run for a few seconds.
BC
#205
It's always the simplest things... I didn't see it mentioned in this post (though it may be), but found the answer in another post Pewter had regarding this same issue - and it's the relay. He mentioned swapping the fuel pump relay for the horn relay in his post, and sure enough, that did it. Now when power goes to the horn, the old fuel pump relay buzzes, but it didn't make a sound when in the #35 spot. I read some other comments that say to only use the GM relay, not a generic replacement, which these are. Whether or not that is correct, I'll drop in to the dealer today and get several of these. Thanks for the help, Bill
#206
1999 C5 complicated starting issue
Mr. Bill Curlee,
I wish to thank you in your exceptional review and repair of the 1997-04 ignition switch Chevrolet Corvette. My wife and I have had an on-going issue with the vehicle starting and driving for four to six months. So bad, she will not drive the vehicle as it my leave her stranded and I would have to remedy the no start. The vehicle will sometimes start or hesitate to start. When it hesitates to start, the dash cluster will die completely (no cluster sweep), no pump fuel engagement, or sometimes the starter will clunk, disengage-clunk on and off rapidly. I would drive it and the vehicle would die under 5mph speed with no switch power, leaving us at great risk stalled in traffic.
I’m mechanically inclined, so I got to fix this so she can drive it. I found a Delco ignition switch (D1499C) on Amazon for 43.91 shipped. So I started off into Google and found that my old haunt The Corvette Forum may have an answer. Searched for how to install an ignition switch and found your review/repair post. I said “..what the hell, I’ve got one coming anyway!” and ripped into the vehicle. And what do you know, the same two contacts/spring-contacts totally charred. I polished those surface areas to an almost shine, cleaned the area of debris, and reassembled the switch (properly). Then I reinstalled the switch into the vehicle, reconnected the battery and with 30 random key cycles not a failure, hiccup, or no-start condition.
My wife and I do appreciate the kind review and the service that you and this forum exchange information to help those in need. And now, we've gotta drive her vehicle.. *big smiles*
airdeano
airdeano
#207
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres another useful thread that I made last night. I see people with this issue all the time:
http://forums.corvetteforum.com/c5-t...post1580770529
BC
BC
#208
Location: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Bill, you saved my bacon yet again buddy!! The last time was when I was getting water in the BCM well and you showed me where the drain plugs were and how clogged up they can get...well this time it was the no start scenario and after buying a new key (figued the contacts on the old one were worn down), still had this issue. Long story short, I took the ignition switch off, performed the Curlee surgery on the contacts and VIOLA!!!, starts up everytime, no issues. I have a long running bill with you my friend and am afraid to ask what the total is now! You a blessing and inspiration to our community Bill...can't thank you enough
Best regards
Mo (your Canadian apprentice!)
Best regards
#209
Supporting Vendor
Great write up Bill!
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
#210
Veteran
Bill,
What about the "pull key, wait 10 sec" message? I've been getting it lately. I tried cleaning it with compressed air and electronic spray. The only time it starts without getting the message is when I spray the key with the alcohol cleaner right before I insert it. If I don't spray it I get the message. It's the same with both keys. What would you suggest?
Thanks,
Rock
Thanks,
Rock
#211
Does this sound like an ign switch issue?
Car runs fine, but when I turn it off and remove the key, the chime dings like the key is still in the ignition. If I try to lock the doors, it double dings like it's telling me the key is still in there.
#212
2018 C5 of Year Finalist
St. Jude Donor '14,'18
ign switch
I told the mechanic that I'm not replacing a perfectly good starter. I showed him the picture of the solenoid with corroded connections. He thought for a few minutes and remembered his 99 Vette had a problem that was similar. He told me the next time it happened to jiggile the key in the start position. It worked. For a measly $53 I bought a new AC Delco switch. For that kind of money I would not mess with repairing one.
#213
CI 6,7,8,9,11 Vet
St. Jude Donor '08
#214
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill,
Thanks,
Rock
Thanks,
Rock
Bill
#215
Bill PLEASE HELP
bill, can i call you,,very hard to explain problem..if so my email address is lolosmaggie@gmail.com Thank you so much.....
#216
Wow! After reading all 11 pages, I guess I'll try to see why my security light is coming on and staying on. It's been great weather lately so I've been parking the Z and taking the bike. Occasionally I would get a Charge System Fault on startup..so not sure if I have an ignition switch issue or battery going flakey. This morning though, the security light stayed on after startup. I killed the car, restarted, it went off but came back on after driving a few hundred yards. So I went back home, got my 2nd key, and the light stayed off till after about 30 miles. Got to work, killed it, restarted and it's off. Need to go out at lunch and pull codes.
So Bill, in your most excellent wisdom, which way to go? Battery, or pop out the ignition switch?
Richard
Richard
#218
Need some pointers
I picked up a used ignition switch off flea bay. I wanted to use it as a spare and fix the contacts and just swap switches to save down time. I need some idea on how to remove cylinder on the replacement switch. I have no key.
