Originally Posted by ~STOLEN~
(Post 1590245381)
Your user name explains everything we need to know.
With replays that are not useful at all like the one you posted, you may have a tough time on this board. Just a fyi......bro |
Simple differential side seal replacement
Years ago, I read a post by cajundude on a simple method to replace the differential side shaft seals but the reference is now dead. I found it elsewhere on the web:
http://web.archive.org/web/201012091...tshaftseal.htm |
Originally Posted by pewter99
(Post 1562078261)
Try this one http://www.lieblweb.com/c5seatfix.html |
Originally Posted by rollin59
(Post 1595356447)
(Post 1561976002)
***Updated, cleaned up 08/04/12****I finally got around to cleaning this up AGAIN, re-numbering things and removing unnecessary stuff. I also moved some links in here that were former sticky threads to clean up the section. I hope everyone enjoys this thread and if you have something to add by all means post it up and send me a PM to get it added to the list!
Robert The purpose of this thread is to try and consolidate all of the DIY and How To's posted here in the tech section. I know alot of forum members have posted threads on how to do alot of stuff from swapping out lights to fluid changes and painting calipers. Alot of these threads have some great information and some very helpful pics and tips so in an effort to get everything in one place and save some time searching I encourage you to let me know about a good DIY thread so I can include it here. I am not saying don't post it in the section but let me know and I will add it here so it will be easier to find in the future. I will start a table of contents in this post and try and update it as things are added...please PM me if you post an article in here so I can update the TOC. A very useful link Bill Curlee's list of must have info http://forums.corvetteforum.com/c5-t...ould-have.html Weights,measurements, ratios, strengths etc http://forums.corvetteforum.com/c5-g...s+measurements Post #2 C5 Headlight gear replacement ****also see post #22 for other version** Post #3 Installing Clear Corner Lights Post #4 Connecting wideband via EGR or A/C Pressure in HP Tuners Post #5 Reuse original shift boot with C6Z06 shifter/knob Post #6 HOW TO PUT 99-02 PCM into 97-98 Corvette WITH PICS! Post #7 & 48 How to replace TPM sensor batteries Post # 8 Narrow band oxygen sensor emulation with a LM-1 wide band Post # 9 AC Refrigerant charge level Post #10 Intake manifold Removal Post #11 How To Fit C6 Fender Guards on a C5 Post #12 DIY Trunk Lid Liner Post #13 Sun Visor Fix Post #14 Heated Seats Installation Post #15 Retractable Antenna Fix Post #16 How to fit a Pioneer AVIC N1 Post #17 Simplified differential output shaft removal Post #18 Outside mirror repair Post #19 Installing interior electrochromic mirror Post #20 Repair Dim HVAC controller Post #21 How to fix leaking turn signal housings Post #22 Headlight gear replacement (version #2) Post #23 Rocking Seat Fix Post #24 How to install a FAST 90/90 Post #25 How to install Auot Dimming mirror in car that didn't have one Post # 28 DIY Rear Hatch Mechanism fix. Post # 30 How To Refurbish a C5 Hoodliner Post #31 Z06 screened Front License Plate Mod Post #32 Popping rear axle fix Post #33-35 Corbeau A4 Seat and Rail Installation Post #36 DIY Exhaust Hanger repair - without ordering the hanger. Post #37 Front License Plate Fresh Air Screen Mod Post #38 How to refinish your C5 clear Targa Top..... Post #39 Headlight switch failed. Decided to repair instead of replace… Post #40 dash removal and HUD install Post #41 Vette Essential's Full Custom Seat Cover Replacement Post #42 TheRadioFlyer's LED "halo" tail light mod Post #43 Vette Essentials: Replace any interior piece: shift boot A4 and MN6, counsol lid, ect Post #44 bunch of misc links, threads, and DIY's ..if you can't find it elsewhere Post #45 Leaky rear fix...with pics Post #46 Replacing TPM batteries Post #47 Multi-Function Switch / Headlight Switch / Blinker Arm Removal Post #48 - DIY Flasher Bypass. Post #50 How to lower your C5 (3 different threads) Post #51 DIY Repair a curbed polished rim Post #53-56 Fix airbag light that stays on Post #58 Power Seat Issues (formerly a sticky thread) Post #59 Oil Pressure Sender Relocation How To (former sticky) Post #60 How to fix exterior mirrors with broken swivels (former sticky) Post #61 C5 Differential Rebuild Post #62 How To Properly Jack Your C5 Post #63 How to replace your AC compressor Post #64 Door handle LED install Post #65 Service ABS, Service Traction Control, Service Active Handling and EBCM Tutorials Post #66 Evil-Twin's Rotor Cleaning Technique Post #68 How to Replace Halo Weatherstripping on a C5 Coupe Post #69 Clutch Install guide from forum member Dope Post #72 Upgrade TPMS Post # 73 Oil pressure sensor replacement without cutting or intake removal Post # 80 The $40 fix for broken side bolsters [pics] Post #81 Tips on shocks, sways and lowering Post #82 Clear Corner lights Version #2 Post #83 AntiVenom Mod Post #84 Flasher Switch Post #85 Another DIY Jacking Puck thread Post #86 DIY AR Header Install on my 1997 C5 6 speed car (by bucketlist1957) Post #87 Z06 rear Brake Duct Template * FREE * Post #90 Link to C5 DIC Codes Post #91 Torque Converter Install Post #92 Lowering C5 the right way Post # 94 When air comes out of all AC vents: How to Fix w/Pics Post #95 How-to-repair-EBCM-avoiding-costly-repairs-through-ABSfixer-or-Fleabay Post #98 Window Motor Rebuild Post #100 Links to Steering Position Sensor Post # 101 DIY for adding AUX Input using GM10-AUX do not need COR HAR Harness Post #102 Headlights stuck in bright / dim Fix Post # 103 DIY GM #12102635 for TPMS upgrade Post #104 Sideskirt DIY...make your own...10-13-2011 Post #106 How to remove stock control arm bushings with only a vise and free Autozone Loaner Tools. Post #107 Lazymans Rocking Seat Fix Post # 108 Weights, measurements, strengths etc. Post #109 Fuel Regular, Premium, Real Gas Post #110 Planning on Wheels and Tires? Not sure which tires to go with? AH/TC issues? Post #111 Making the C5 go the distance! Post #112 The Anatomy of a Hydraulic Lifter Post #113 Multifinction Turn Signal Lever Post #114 Engine Grounds Post #115 1997-2004 PCM Pinout Post #116 C5 Ignition Switch Repair Post #117 C5 T56 Rebuild 5th-6th Extension Shaft Details Post #118 Leak Checks Post #119 Opinions on Propshaft Rubber Couplings Post #120 ACA HID install prep - bulb jiggle "fix" Post #122 Sound Deadening and Stereo Install (step by step) Post # 123 Fast 92 intake with LS2 Throttle Body install Post # 124 An Alternative Fix For The P1416 Code Post # 125 C5 steering wheel with a regular steering wheel puller Post # 127 How to get your seat out when there is no power or broke Post # 128 Mesh Side Cove DIY Post #129 Dipstick Mod Post #132 How to check fluid level in A4 Transmission Post #135 18 minute hazard switch replacement Post #136 DRM transmission cooler install process pictures and helpful hints Post #142 Adding AUX/iPod jack into the stock C5 Headunit Post #143 Install a DRM Transmission cooler Post #144 How to stripe your Vette using the PlastiDip product. Post #145 How to install 9000 pound twin post lift |
Originally Posted by DeeGee
(Post 1562023038)
I'd been seeing the trunk lid liners on some of the members Vettes but being a good Yorkshireman, the $150 price tag seemed a bit steep.
Had a bit of a DIY morning and made one up myself A sheet of pegboard - Home Depot $3 A roll of black carpet from Walmart - $8 Spray Glue - Lowes $4 Velcro - Lowes $8 I made a template from some wrapping paper and transferred it to cardboard. Then used the template to cut the pegboard. Shaped the edges to make it fit the space using a rotary cutting disc. Glued the carpet to the pegboard leaving a 2" strip. Folded that over the edges and stapled around the edge after priming with the spray on glue. Fixing proved tricky. I tried velcro on the V Channels on the inside of the trunk lid but the weight pulled it away continually. I decided to use push fit studs which hold the liner in place a little better. Four studs were a few extra $ from Autozone. Attachment 48168386 Mark positions for the studs carefully. Drill holes through the liner into the V Frame. The stud pushes through and fits tightly into the frame behind. There are 2 studs at the top and 2 at the bottom. Most Important: Be very careful not to press too hard and drill through the trunk lid Voila, the end product: Attachment 48168387 The logo was embroidered by my wife. You could buy the commercial GM logo but that would add to the cost. An enhancement may be to fit some foam blocks at the lower outer corners. This would prevent some minor flexing |
(Post 1563388357)
Refurbishing a Corvette C5 Hood Liner
The liner is made of a very delicate material so be careful in how you handle it once it’s removed. The surface is a fabric type finish and hard brushing will cause it to become rough and fibrous. It will also crack easily if you let it flex so if you take it outside beware of strong wind. As you take the final fasteners out, support the liner so you don’t crack the liner around the eyelets. The actual work takes only minutes. The drying time is the only slow process. As you can see, the liner will have attracted quite a bit of dirt and grime. Attachment 48166253 OK here we go. Lift the hood. Remove the fasteners gently, top, then bottom and middle ones last. This will support the liner better as you take them out. Us a tool with a forked end. I’ve heard of a barbeque fork being used. I used a nail puller work in behind the fastener. Attachment 48166254 Take the liner outside and brush the surface gently with a soft brush to remove any dirt. Take care not to damage the surface of the liner. Attachment 48166255 Spray the liner with black paint. The difference between the old and the new surface is immediately apparent. Attachment 48166256 Use as many coats as you see fit. The liner is porous so it will take at least 3 coats to get good coverage. Leave it for 30 mins between coats to allow the paint to dry. Attachment 48166257 If you plan to paint the Corvette emblem, you may wish to apply extra paint around the embossed area on the liner. This will stop the liner absorbing the coloured paint. Once the paint is dry (and you may wish to leave it overnight), you can either paint the emblem or apply a decal. I chose the decal. Alternatively if you prefer, you can refit the liner and apply the decal when it’s back in place. Refit the liner in the hood fitting the middle fasteners first to hold it in place, then refit the remaining fasteners. A gentle push fit is all it takes to reinsert the fastener. The finished Hood Liner Attachment 48166258 |
Originally Posted by Rlb2002vette
(Post 1596666045)
Hello, I'm a newbie here. I just found your section, WOW.you've got answers to questions I hadn't even thought of.I have a 99 C5 with about 40,00 on it. Its in great shape but I do want to do some things to it. I put a Air raid air filter on it and hall's and replaced halogen with led that was a big improvement. Ty for sharing your knowledge and information for all us underclas men.
(Post 1596705594)
Thanks...this thread needs some serious attention again...just haven't had the time to do it....lots of helpful folks here who made this thread possible
This thread was very helpful. Instructions were clear and worked as stated! Took me about 10 mins.
I also completed #2 after ordering gear from Rodney. Longest part of process letting glue dry overnight. I also replaced the stops.
thanks |
