Tire sensor lifespan?
Old 08-09-2003, 11:40 PM
TOPGUN9
TOPGUN9's Avatar
Default Tire sensor lifespan?
Anyone know the average lifespan of a tire sensor monitor before the battery wears out?
Old 08-09-2003, 11:54 PM
Bill Reid
Bill Reid's Avatar
Default Re: Tire sensor lifespan? (TOPGUN9)
The 97-00 units are starting to fail a little more regularly now. 5-7 years on (more or less) a watch battery isn't bad... just sucks to change them... along with the expense :eek:
We normally carry replacements in stock. Give us a call if you need one :)
:cheers:
[Modified by Bill Reid, 9:54 PM 8/9/2003]
Old 08-10-2003, 12:32 AM
Richin Chicago
Richin Chicago's Avatar
Severe temperature cycling will cut it down but the lithium batteries should be good for about 10 years. Which means early failures should start showing up on some c5s now.
Old 08-10-2003, 08:31 AM
AFVETTE
AFVETTE's Avatar
8 to 10 years. Of course individual driving conditions may affect that (probably downward) their life to 6 to 8 years.
Tom
Old 08-10-2003, 10:28 AM
nevrenuf
nevrenuf's Avatar
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
I don't know.. my experience is alot worse than that posted..
On my 99 coupe, I had two replaced before I dumped it.
On my 00 coupe, I had two replaced before I dumped it.
On my 02 coupe, I just had my first replaced..
Old 08-10-2003, 12:13 PM
85USA1Coupe
85USA1Coupe's Avatar
Default Re: Tire sensor lifespan? (nevrenuf)
these early failures , were they from the rear tires where you spin them up more?
Old 08-10-2003, 02:56 PM
rhoeven
rhoeven's Avatar
The sensors switch themselves off if not in use so I think their life span is mileage based instead of time based.
I have 67K miles on my '99 and so far I had to replace the RF sensor. It just started giving a reading above 55Mph.
All others are still original and working fine.
Roger
To Tire sensor lifespan?
Quick Reply: Tire sensor lifespan?
