Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Old 10-20-2012, 05:20 AM   #1
JC218
Junior Member
Default C5 Will not Start
Need Help,
I have a 2003 with 23400 miles on it and it was running fine. Went to start it and all I get is clicks on the inside of the car with no starter action. I read the forum and pulled my Ignition Switch. I followed the direction posted by bill (thanks Bill) and it Ohmed out good. It looked good with really no burn marks. I reinstalled it. I get all dash lights but when I turn it over to the Starter position, all lights go out like it has a bad ground. I pulled the cables clean and retighten, checked battery and it is fully charged. I jacked the car and turned on the key on. Jumpered the purple wire to the hot wire and the engine turned over, started and immediatley died. I did this several times with the same result.
Any Ideas would be helpful.
JC
JC218 is offline   Reply With Quote
Reload this Page C5 Will not Start
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1988 CORVETTE will not crank over but has 12 volts to lights, etc. kennyh19 C4 Tech/Performance 22 11-10-2013 10:32 PM
HELP S.O.S.! '79 won't crank over mitchbloms C3 Tech/Performance 10 08-20-2013 06:51 PM
No Start JC74 C3 Tech/Performance 16 07-29-2013 09:54 PM
Ignition switch/button problem.....I think secrt0007agt C6 Tech/Performance 5 07-23-2013 10:48 PM
C5 will not start JC218 C5 Tech 16 10-25-2012 01:16 AM
Emails & Password Backup
