Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Old 06-09-2011, 10:04 PM   #1
SCRMNC5
CF Senior Member
SCRMNC5's Avatar
Default Charge system fault!!!!!!!!!!
I need some help guys!!! got this display for Charge system fault the other day. bought a new battery and alternator just to make sure. put them both in and still had the same display up, with a voltage reading of 11.2-10.9. Talked to a buddy told me to make sure my connections were tight on the starter, I did, and got almost a full turn on that bolt. Put everything back together and the voltage went back up to 13.2. Took the car out today, and the voltage kept going down, and eventually I lost all the gauges on the dash then shortly after the car shut down, dead!!!!!!! Had a new battery driven out to me at the car, installed it and ..........nothing, wouldn't even turn over. Is my starter fried??? and if it is will it cause my whole system not to charge?? Please, any info will be greatly appreciated, as I am going to be doing the work myself. Thanks in advance.
Barry
SCRMNC5 is offline   Reply With Quote
Old 06-10-2011, 07:48 AM   #2
dgrant3830
Wounded Warrior Escort '11
Support Corvetteforum!
dgrant3830's Avatar
Send a message via AIM to dgrant3830 Send a message via Yahoo to dgrant3830
There is a fuesable link between the starter and the alternator. Put a meter on the large red wire on the alternator when the engine is off and see if you measure any voltage there on it.
dgrant3830 is offline   Reply With Quote
Reload this Page Charge system fault!!!!!!!!!!
Tags
2004, battery, c5, charge, corvette, fault, forum, system
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
