How much oil does your car take?
#42
, The filling of the oil from the factory will be 6.5 qts. The cost factor associated with having it wrong keeps very close control of this step.
The comment in the manual is there because a lawyer told them it would be in their best interest to have the disclaimer, not an engineer.
Yeah, lawyers determine the technical specifications of car.
The ONLY way that the dipstick could be the tell all for proper level is if every oil pan was perfect, every dipstick tube, dipstick, and the hole it fits in the block would also have to be perfect. GM is good, but not perfect. The oil pan supplier or any of the other parts can change during a production run. This can change the level that shows on the dipstick.
Hey, I'm sure any C5 will be happy with 6.5 qts added at an oil/filter change ... but what if adding 6.5 qts put the level at the "L" mark on the dipstick? ... would you ignore the dipstick reading and just run the 6.5 qts because the service manual said it was the "approximate" amount required? I certainly woudn't.
#43
There are other documents that give the proper design value without the disclaimer like the one I referenced earlier.
As far as your car coming from the factory with the oil at the full mark, ever think that the dealer may have added some?
Glad to see you read your manual.
Your saying GM can get EVERY variable that would effect the correct amount of oil to add perfect (they would need to, in order to tell you the perfect amount of oil to add, which would include an oil pan that you've already stated GM can make good, but not perfect) but they cannot get the parts used to indicate the oil level perfect as well?
Also, I doubt the statement telling you to check your oil level was added to satisy a lawyer. Though even if it was, i'll continue to check my oil level and fill to the appropriate level, as I would with any other fluid in the car. You can continue adding 6.5qt's and calling it a day, and hopefully; this thread can end.
#45
Just for the Record, I had the rear of the car aproximately 4 inches higher than the front when I drained the oil. I let the oil drain for approximately 40 Minutes. I then removed the oil filter and let it drain for approximately 15 more minutes. I then filled the oil filter lubricated the seal on the top of the filter and installed it. I then installed the drain plug and put 6 quarts in ran the engine for 10 minutes then let it sit for 20 minutes and checked the dip stick. Then added another 1/2 quart stared the engine let it run for 10 minutes and then let it sit for another 20 minutes. Checked it again then added the final 1/2 quart to get to the full mark on the dipstick. Total 7 quarts not including the oil in the filter. Now you know exactly what I did and why ...Dave
