C5 and Michelin run flats. Bad Idea!
I was really glad to get the Goodyear run flats off of my C5 because of the noise and rough ride. I then bought a set of Michelin Pilot Sport A/S Plus ZP run flat tires. I put 12k on these Michelins and both rear tires developed a complete crack around the entire tire where the part that hits the road and the sidewall begins. Michelin would only give me a 90% warranty and I had to pay the other 10% to get new Michelins.
I hope this is an isolated event but if you have or have heard of this please post a reply and let us know if Michelin run flats are bad tires.
Also, if you have found a better run flat tire please post your experience. Thanks
Received 3,812 Likes
St. Jude Donor '03-'04
You used 30 % ( 12,000 miles ) of those rear tire's life and they are replacing them for ONLY 10%.
It should have been a 100% warranty replacement as it was a fault of the tire maker. A complete crack around the tires, especially with low miles on the tires, is a fault of the tire maker. For that matter, I have 12 year old tires on my lawn tractor and they don't even have dry rot!
Received 1,673 Likes
I think they were fair with you.
Whether the tire had a defect or not, you used them for 12K miles. When a car manufacturer recalls a car because of a defect, they DO NOT give you a new car.
You got way more than a fair deal........
On a side note I have had problems more than once with similar cracks on Michelin tires and for that reason no longer will use them.
6 Years / Free replacement first year, 2/32" or 25% of wear, then prorated until 2/32" remaining depth
When my tires were checked they had 9/32" tread left. So only 1/32" had been used so a full replacement should have been done.
On tire rack . com you can see the warranty for the least expensive tire for my C5 which is a Sumitomo HTR Z lll. The warranty for this tire is:
6 Years from production or purchase / Free replacement for 6 Years from date of purchase or worn to 2/32" remaining depth
Be that as it may, for a tire that has a crack around it like mine did, I will not purchase Michelin tires again. Makes no difference about the 12k miles on the tire. The damn things were made wrong and were coming apart!
Anybody found a better tire that they like better?
They should have replaced the tires for free, including mounting and balancing. The tires had dangerous defects that could have resulted in an accident.
Thoroughly chapped
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Never had a problem with mine, other than the typical run-flat stuff (noisy, less performance, etc...).
Matter of fact, rather than throw them out after changing to Pilot Super Sports, I put them on my daily-driver, where they are working just fine (probably 20k on the front ones, 7k rear)
I had a set of those for 6 months....sold them because they sucked
Received 19,236 Likes
'20-'21-'22-'23-'24
You really need to state how long you had the tires on the car. If greater than a year, then Michelin was fair in what they offered you.
I think the best run flats right now are the PSS ZP that come stock on the C7. You'd need new wheels to run them though. I think base C6 wheels with spacers in the rear would be the most economical option.
Seriously, drove 12K on the tires and got brand new ones for 10% and still not good enough
Average daily driver is expected to accumulate about 12K miles per year. Don't know if the OP uses the car as a DD but somehow I don't think so and even at that this would put the tire at 1+ years old. I think they did you wright and stood by their warranty.
Here is the Michelin warranty:
michelin is probably the highest quality tire manf. on the planet. their only real contender is yokohama and generally michelin makes a better tire
don't let one bad exp turn you, tires should be replaced on a sports car at 4yrs regardless of mileage anyway.
you got a GREAT deal from them. 12k miles is what? half the life of the tire for the average driver? more important are years. that 6 year policy they have is REALLY generous
if you really only used 1/32 in 12k miles you might want to re consider why you own a sports car in the first place
you're crazy
I had a horrible experience with top of the line OE Michelins on a new Subaru. They were shot after 20K miles. I would never buy them again. I know people that have had similar experiences. What makes you believe they are the best tires on the planet? Having tread separation on a pair of Michelins after 12K miles are not what you expect from a quality tire. It sounds like they were not abused.
as for my comment on them being great, their new compounds, like the pilot super sport are downright fast for a street tire that can go the type of mileage they do. this is a utqg 300 tire that by all measures will go a whopping 25-30k miles and compete with tires that average maybe 15k miles a set. they are also extremely fast in the rain, like north of .9g in a downpour. currently no one else has a tire that will do everything this one does, the only close competitor is yokohama with their advan v105
if you wasted a set in 20k miles and they were OE for subaru one of two things comes to mind. either the toe in the alignment was off..which can happen even on new cars, or, subaru spec'd a soft tire to make the performance numbers look good. my guess would be the alignment
if you're bent at michelin as a whole for some reason, my second choice would absolutely be yokohama if i had to just pick brands. honestly it should be tire model, not brand as all brands make bad models at some point. yokohamas prada 2 was a POS if ever there was one. most of their passenger tires are really good though, same with sport tires
we have no answer on how old they are, age is far more important for tread separation issues, even if we assume they are under 4yrs old duds do happen with all brands
