What did you do to your C5 today?
Quick pic, just for fun.
The following 6 users liked this post by LiManZ06:
Bobbo76 (04-24-2024),
C7ZO6 (04-23-2024),
capevettes (04-24-2024),
Kubs (04-23-2024),
Tusc (04-23-2024),
and 1 others liked this post.
I’ve owned my 2000 M6 for almost a year now and have been learning a lot about the C5. Based on what I’ve been reading on this site it seems as though keeping the clutch fluid fresh is as important as changing the oil. It’s too bad GM didn’t give us any reasonable way to properly bleed the clutch fluid.
Now, add power to the mix, etc. and all bets are off. And, yes, put in a remote bleeder when the opportunity offers itself.
HTH, and have a good one,
Mike
PetrofMII (04-23-2024)
Received 1,768 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I drove it to work today!!
Between kids sports, church events, etc. it took about 10hours this weekend to pull and rebuild the torque tube and replace the clutch. Last night I got all the fluids changed and went for a test drive. No more bad vibration and everything seems to be working well. Still left on the list is to check the corner balance and alignment, and make sure the trailer is ready since I haven't even looked at it since October, lol.
The following 12 users liked this post by Kubs:
acroy (04-23-2024),
capevettes (04-23-2024),
drtyTshrt (04-24-2024),
Eshoremd (04-23-2024),
and 7 others liked this post.
Kubs (04-23-2024)
I got the car last Wednesday, so I'm just taking care of little things as I learn. The remote bleeder is definitely high on the list. It doesn't sound like the slave is accessible to install the fitting for the remote bleed unless the exhaust is off the car. Is that correct?
Yes sir!
VetteDrmr (04-23-2024)
To add to what @Kubs shared, the Katech remote bleeder might be the only (or at least best) option that can be installed with the drivetrain intact. Definitely need to drop the midpipes and clutch inspection cover, and it's a tedious job with low clearance. Not difficult but very trying of your patience.
Tusc (04-23-2024)
Received 2,265 Likes
Received 1,872 Likes
Tried to get my 2001 vert inspected, today. It failed the emissions test.
Back to the drawing board.
Mr. Black (04-23-2024)
Plugging away on putting her back together. Got the intake, tb, belt, passenger side exhaust, dipstick 9000, generator, and coils mounted. Having a beer. 🍺
The following 6 users liked this post by vette4fl:
Eshoremd (04-24-2024),
Markolc1981 (04-24-2024),
Mr. Black (04-23-2024),
Prop Joe (04-23-2024),
Smoken1 (04-23-2024),
Drove 480 miles to Bowling Green for the Bash which starts Thursday. Doing the factory tour this afternoon.
The following 7 users liked this post by bradc6:
cdee63 (04-24-2024),
knewblewkorvette (04-26-2024),
Kubs (04-24-2024),
LiManZ06 (04-24-2024),
and 2 others liked this post.
Had a track day about 10 days ago. Bumped up to the next group because I was tired of getting stuck behind slow cars. Hung on pretty well, but there's still room for improvement and I get absolutely gapped on the straights by everything that has more power. Really drove the **** out of it every session, the driver's side splitter puck will have to be replaced soon. I think it's about an inch off the ground in this pic.
Since I now have a new exhaust, it was finally time to get to work on my transmission cooler setup (about a year after I started collecting parts!). Finished mounting up the cooler last night. Now I just have to figure out all the line routing and running wiring. Hopefully I'll get that done next week. Might fab up a little fender liner extension for the front to provide some additional protection from junk that gets kicked up from the tire.
The following 9 users liked this post by G_Loc:
JeffT1 (04-24-2024),
Kubs (04-24-2024),
Midwayman (04-26-2024),
and 4 others liked this post.
She’s done, running, driving. The new LS7 lifters were noisy at first but quieted down some after the engine warmed up. I should say they are quieter than the Comp Cams lifters, but noisier than the original stock setup. I’ve never heard noisy lifters on a hydraulic cam before, so this is surprising for me. Somewhat disappointed as it is not a fun sound.
I have been told that it’s the nature of having a cam with steeper ramps. If that can be solved with less lift, or a different ramp design, I will consider a change. On the plus side, the engine fired up immediately, and was happy to blow the tires loose on a quick stab rolling in first gear. No leaks observed. Yay.
The steering still sucks. I tried a different fluid, Mercon, which has a horrible smell by the way, and no improvement. This is a bit perplexing, but on the other hand I have the cleanest power steering fluid on the block. I may just have to hand this problem off to a pro.
Kubs (04-25-2024)
IDK if this is your problem or not, but just a guess.
Have a good one,
Mike
I went back about 4 pages and didn't see what problem you're having. Assuming you have air in the system (drove me crazy when I had to replace the rack), I finally got it bled by making a nice easy pull up to about 5k rpm (I used an on-ramp up to about 70 mph to keep the revs up for a decent duration), and that did the trick.
Have a good one,
Mike
Have a good one,
Mike
Thanks for reminding me.
5k rpm blast around an off ramp in a car with suspicious steering seems like a GEAT idea LOL.
vette4fl (04-25-2024)
Have you tried running the car in the driveway and just slowly turning the wheel lock to lock a few times? That should help bleed out any air.
