What did you do to your C5 today?
Old 04-22-2017, 06:32 PM
  #41
ErikwithAK01
ErikwithAK01's Avatar
I just did the top end, I don't use anything in the oil. 5000-7500 mile intervals, and Mobil-1 since the factory have left nothing inside the crankcase of my LS I've seen engines run on dino oil that look worse than mine at 10K...and mine's got 95K!
Old 04-22-2017, 06:59 PM
  #42
BRKLYN
BRKLYN's Avatar
Default Cruising
Went for a cruise on the north shore. Temperature 82 sunny felt like 90, top was off
Markwall (12-08-2020)
Old 04-23-2017, 07:53 PM
  #43
bonzo
bonzo's Avatar
St. Jude Donor '12
Drove it like you are supposed to do. Daily driver even on the weekends!!
Brickbuck (10-24-2022)
Old 04-23-2017, 08:07 PM
  #44
4XLR8N
Pro Mechanic
4XLR8N's Avatar
Received 1,655 Likes on 1,211 Posts
Woke her up from a long winter's nap!
Old 04-23-2017, 08:08 PM
  #45
Dave1998
Dave1998's Avatar
Went out for a cruise today as sun was out and a beautiful day here in Central, PA.
Old 04-23-2017, 08:54 PM
  #46
Crosis
Crosis's Avatar
My front C6 Z06 shocks arrived today
Old 04-23-2017, 09:44 PM
  #47
JC316
JC316's Avatar
Changed the completely wore out adjustable shocks with some stock quality Gabriel shocks. Now speed limited to 80mph, so either need a tech 2, or hit up a radio shack. Then I discovered that the drivers rear upper control arm mount had broken loose from the frame, so I welded that **** back on. Drives a whole lot better now.
Olnavy (03-27-2023)
Old 04-23-2017, 09:53 PM
  #48
Mayor111
Mayor111's Avatar
Received 1,959 Likes on 943 Posts
Took my C5 (and my C4...shhhh) to a Car Show today...
The following 3 users liked this post by Mayor111:
Ciro's C5 (01-15-2023), jpm995 (05-07-2022), Mike Bewley (07-18-2021)
Old 04-23-2017, 10:32 PM
  #49
mjfrank
mjfrank's Avatar
Finally replaced my factory original, all cracked to hell, DRL/Marker light housings. Now I'm thinking I need some LED DRL bulbs, because the sockets were starting to look a little toasty.
Old 04-23-2017, 10:50 PM
  #50
Rob 02
Support Corvetteforum!
Rob 02's Avatar
Worked on the passenger rocking seat.
Old 04-24-2017, 12:31 PM
  #51
awches
awches's Avatar
Quick wax job and appointment for this afternoon for alignment on my 110K plus 03 Coupe.
Old 04-24-2017, 07:44 PM
  #52
pjdbm
pjdbm's Avatar
Installed these today, very happy
The following 2 users liked this post by pjdbm:
Markwall (12-08-2020), MrLarge252 (05-20-2023)
Old 04-24-2017, 08:06 PM
  #53
friou
friou's Avatar
Had every intention of getting the cover off and going for a cruise, however, a fine bottle of red wine, beautiful dappled sunshine and a adirondack chair under a pecan tree in my front yard derailed my intended automotive pursuits for the day. Well, there is always tomorrow, supposed to be just as nice, clear and in the 80's. I'll get her out then. Best wishes to all!
Old 04-24-2017, 08:26 PM
  #54
awches
awches's Avatar
Had the wheels aligned. Was way off. Feels so much better now. Not hunting all over the road due to plus toe end. Our local front end shop did one heck of a job.
Old 04-24-2017, 08:55 PM
  #55
hornet7
hornet7's Avatar
Default What did you do to your C5 today?
Finished detailing my 98 coupe using the DA polisher and Meguiar's car care products. Man she's looking good.
The following 3 users liked this post by hornet7:
Ciro's C5 (01-15-2023), Markwall (12-08-2020), redhotttvette (09-19-2020)
Old 04-24-2017, 10:18 PM
  #56
motorboater222
motorboater222's Avatar
where did you find these? Love the cutout for the foglamp.
Old 04-24-2017, 10:36 PM
  #57
pjdbm
pjdbm's Avatar
https://www.corvettemods.com/, I also found a coupon and used it, I am going to order the rear laser mesh also when I save up some money.
To What did you do to your C5 today?
Old 04-25-2017, 05:27 PM
  #58
Crosis
Crosis's Avatar
My rear C6 Z06 shocks and my hyperflash harness arrived today
Old 04-25-2017, 05:51 PM
  #59
doublenut9
doublenut9's Avatar
Replaced air dam under the front and installed a screen for radiator access
Old 04-25-2017, 07:19 PM
  #60
awches
awches's Avatar
Pulled all 4 wheels, clean and dilectric grease on the ABS plug in's. One was loose fitting on the bracket so tighten that up.
Still getting a c1214h on the TCS system at times.
Start chasing grounds tomorrow.
Quick Reply: What did you do to your C5 today?
