Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Old 01-07-2010, 08:21 PM   #21
Silverbullet00
CF Senior Member
Silverbullet00's Avatar
Location: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Quote:
Originally Posted by Blue 92 View Post
Did you have it load tested?
Sounds like a bad connection. The C5 is ground sensitive and there are more grounding points than you would think.
Bill Curlee has a great post on locating and checking ground points here: http://forums.corvetteforum.com/c5-t...o_threadsearch
Quote:
Originally Posted by slvrzo6 View Post
I'm almost Positive it's your IGNITION SWITCH!
The contacts have become Dirty, and is not allow a full contact.
I had this same problem, and the same symptoms your describing. I did the Fix following Bill Curlee's Advice, and everything has been good for some time now. The Fix looks more Complicated than it is. Took me about 2 hours.
Here is the Fix
http://forums.corvetteforum.com/c5-t...ch-repair.html
Great info on grounds and switches but eliminate the battery before you dive into this pit! Don't ask me how I know,,,,unless you need to,,,,and then I will help all I can!
If the battery change doesn't hook you up, send me a pm!
p.s. Doesn't matter how old your battery is. Even new ones fail from time to time!
Silverbullet00 is offline   Reply With Quote
Old 01-07-2010, 08:24 PM   #22
vette.mix
CF Senior Member
vette.mix's Avatar
vette.mix is offline   Reply With Quote
Old 01-07-2010, 08:25 PM   #23
Jet-Jock
CF Senior Member
Support Corvetteforum!
Made a PDF of that link.
Oh you should swap out the battery as this may be your problem. Around $85 for the AC Delco Pro 78-6YR/7YR Series has like a 7yr warranty with a 30/50 month free replacement. For about $100, you can easily isolate that item. And if you had to jump it already the colder air of winter puts stress on them, the weaker one's fall out quickly. (Battery must have a 120 reserve capacity rating.)
Jet-Jock is offline   Reply With Quote
Old 01-08-2010, 03:24 AM   #24
DeeGee
DeeGee's Avatar
Dave Gledhill David Gledhill
Quote:
Originally Posted by 97C5owner View Post
Just checked. Batt connections are solid- HOWEVER----I have had to jump it when i lift my ipod adapter on for a week without driving her.
Before ripping out the ignition switch try a new battery. I still think this is battery related but its impossible to be certain from an online discussion
DeeGee is offline   Reply With Quote
Reload this Page Gauges flicker and car won't start SOS SOS
Tags
a4, b5, car, crank, egnition, electronics, flicker, flickering, gages, gauges, guages, jump, key, start, wont
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
