Hot starting problem
Hello people!
I'm hoping someone has a magic rabbit hidden somewhere, we're having problems with the 89 TPI and I really just don't know where else to look.
I'll start from the beginning;
This car has always had a hard start problem but it's never been a major issue. It would either take ~ 5-7 seconds of cranking to start the first time, or 1-2 seconds of initial crank and then after cycling the key on/off it would then fire right up the second time.
We replaced the fuel pump and that seemed to resolve this problem.
The car then sat for maybe 2-3 months (I know, it's the first time it's happened)
Dead battery aside, it fired right up. We drove it for about 20 miles before it started misfiring fairly badly, but we managed to limp it back home.
When we got back, it wouldn't restart.
Diagnosed that it didn't have spark. We replaced the distributor assembly (it had a new cap,rotor and coil before anyway) and again started right up, but after running it up to tempreature, the car would not start.
it cranks nicely, but will not fire
We verified fuel pressure was OK, and that the car was getting spark.
researching old TSB's we ended up replacing both MAF relays and the car again will start when it's cold but will not start while hot.
I also rented a couple of noid lights but can't really tell if the injectors are firing or not (the bulb seems to light up but it's very weak)
We're out of ideas right now
list of stuff replaced within the last year/ 3K miles;
knock sensor
spark plugs
Most of the 'electronic ignition control modules'
Wire's/distributor.
We did end up being able to drive it up to the post office < 2-3miles away but it was running pretty rough.
We've verified timing is good as well.
At this point we're thinking;
ECM or MAF.
On original injectors.
knock sensor
spark plugs
Wire's/distributor.
ECM or MAF.
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
When I had my 89, it started miss firing and bucking, finally took it to the dealership, they replaced the ECM and it ran stronger then it's done in years.
If was in your shoes, and I was, I would pay dealership to diagnose it, and stop throwing parts that hasn't fixed the problem.
There people here guessing on diagnosing your car unseen, which you know you doesn't work just like throwing parts into the engine.
You don't have to have it repaired after they give you diagnose you can buy the parts and install them yourself if it to much for repairs.
You got my two cents.
so, for future post searchers, this turned out to be fuel injector
car fires up FAST (used to take a long time), runs great and has cured the problem,
we ended up replacing two of the MAF relays on an old TSB as well, but new SS Delphis really fixed the problem. Thanks for all the help!
