C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
All engine ECM's interchangeable?
Old 11-13-2013, 02:28 PM
blownrunner
blownrunner's Avatar
Default All engine ECM's interchangeable?
Are all the engine ECM's interchangeable for our ZR-1's? I am thinking the PROM chip could be swapped in the 90-93 cars, so those years will be interchangeable. What about the 94-95 cars, as I believe they do not have a removable prom? I have a 1991, BTW, thanks.
Old 11-13-2013, 04:46 PM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,017 Posts
All LT5 ECM's have removable PROM's - none are OBD2 compliant and can be programmed like the LT1/4. It's generally accepted that the PROM's are "year model" specific but recently there's been mention of wider "year/model" usage of the ECM's is possible. I've no "first hand" knowledge in attempting changes so I won't comment on that. A PROM may have an overlapping application after updates that were compiled but I believe each model year started out with a specific PROM for that model year.
Old 11-13-2013, 07:28 PM
Dynomite
Support Corvetteforum!
Dynomite's Avatar
Default ECM Interchangeability
Marc Haibeck did some testing.......ECM Interchangeability TIPS
LT5 Performance Calibrations
Old 11-14-2013, 01:47 PM
95ZR1
95ZR1's Avatar
Yes, my '95 has a removeable PROM. So the PROMs are
year specific, but the ECM's are interchangeable. Good
to know. Great work, Marc!
To All engine ECM's interchangeable?
Quick Reply: All engine ECM's interchangeable?
