Can you just "hollow out" a catalytic converter with a broomstick?
Just wondering if this is true. And if it is, is it a good or a bad idea? Thanks-
Re: Can you just "hollow out" a catalytic converter with a broomstick? (gray84)
I found an iron pipe and hammer worked best :smash: :smash: :smash:
Some folks claim that it creates a lot of turbulance in the cat. A straight thru pipe is better.
I say a gutted cat is better than a cat any day.
I had a real tough time seperating my cat from the Y-pipe. Ended up getting a new cheapie just to hollow it out. Used to be able to get 'test pipes' :lol: :lol: but have not seen them around in years.
If you have a friendly muffler man, they might make one up for you. Just don't ask them to put it on. Just give them the exact dimensions of what you need :yesnod:
Yes, you probably can. I had to use a crow bar (similar to the pipe, used above). Mine was melted down to the point that the wooden handle wouldn't have done it.
Is it a good idea? You will get varing opinions on this. Mine was clogged. I had lost a full second in the 1/4. Something HAD to be done, and I couldn't afford a new converter. A gutted converter MAY be worth 2-3 tenths in the 1/4 over a fully functioning converter. Personally, I wouldn't do that to the air we all breath for the improvement. BUT, I do still pass emissions inspection.
If you have the '84 that your user name suggests, the converter is attached by a 4 bolt flange, front and rear. For me, the hardest part of the job was getting working room. Once you have access, all you have to do is remove some heat shields, and wrench away. Don't forget the tube from the AIR pump, but it is a pretty straight forward job, with the flanges.
I used the handle from one of my floor jacks. I don't think the broom handle would have enough mass and "chipping ability" to knock it out. A long screwdriver w/ a hammer would work well.
Depending on the style of the cat, just knocking out the insides can create a lot of turbulence in the exhaust. It might perform better than with the catalyst, but it would be better still if you put a pipe through it. The extra turbulence can also lead to extra resonance.
If there are no emissions in your area, why screw around with it? Just cut it off and save the weight as well.
I think using a pry bar of some sort is the best method to gut a cat. Once the cat is hollowed out, get a length of straight pipe and sleeve the empty cat. It will look as though you have a cat in place, you won't have to worry about turbulance issues either. I guess if you mig weld the sleeved pipe to the cat, it would stay inplace without rattling. Just an idea, I haven't done such a thing but I bet you could.
Re: Can you just "hollow out" a catalytic converter with a broomstick? (M2001)
There are 3 ways to do this: 1- cut your pipe right behind the cat and use a piece of pipe about 18" long and hammer away. It works best on a hoist with the vehicle running. Use a coat hanger to get the pieces out that are stubborn. 2- Take of your cat, open it up, gut it, and reweld it closed. 3- Have your friendly muffler shop cut it out and use a cheater pipe. It usually works if YOU tell them that you would like to make it a cash deal with no receipt. It's against the law for them to do it and this way there is no paper trail to come back on them. Hope this helps. :seeya
The State even goes as far as showing testimonials from muffler shops that have gotten in trouble for this... letting everybody know it can happen to them. The muffler shop I deal with WILL NOT even talk about it he's so scared! For real!
That's a lot to ask from a friendly muffler shop business man.
I'm not giving you heck, Corvette Owners reading that... well, just be aware.
Chuck M
Number 3 option is a tough one. It is a $10,000 fine per pipe, loss of business license, loss of State Inspection License. The muffler shop can't plead ignorance because the State is always harping on them! AND they are NEVER off the hook! If you sell the car and don't take those off, the buyer, whenever they choose, can go after you for new cats when they don't pass. They WILL go after you and you will have to divulge who did it or your out the 20K and new cats (worse case scenario of course)!
Chuck M
Chuck M
Chuck M
Chuck M
By the way, I have only ever heard of one person getting busted and fined for not having cats and that was something on the internet. I don't think the EPA really gives a crap about individual people violating the law. They're more concerned with shops doing it where they can make a lot of money. On top of that, I'm not sure your average cop would even know how to write up a citation for a federal crime like that, let alone know what a catalytic converter even is...
My favorite tool is a sharpend piece of rebar and a big ball peen hammer.I kind of wonder about the stuff coming out-if its poisonous or not.I should be dead by now.I would say you should be wearing a dust mask ,safety glasses and gloves.The sleeving idea is great-I might have to try it some day.
