Im getting ready to check pushrod length. Do I need to do this for all cylinders or just one ?
I do normally check a couple of cyls just to be sure.
It's unlikely that you'll need different lengths but there could be minor differences due to deck height differences or a machining fault on the cyl heads.... However if you found something blatent like that, it would indicate a machining problem somewhere else that won't be fixed with just different pushrods.
