Anybody shorten the length of shifter
Old 01-17-2011, 07:30 PM
gkrynick22
gkrynick22's Avatar
Default Anybody shorten the length of shifter
Hey I would like to shorten the length of the shifter lever. Has anybody done this? If so is it possible to do without compromising the reverse lockout? I am buying a spare shifter assembly to modify so I will have the stock one to put back in if I don't like it. I would like to bring the shifter **** down at least 2". Any advice or tips would be great.
Old 01-17-2011, 07:52 PM
0Paul Ruggeri
Former Vendor
Paul Ruggeri's Avatar
4+3 or 6 speed?
Old 01-17-2011, 07:55 PM
gkrynick22
gkrynick22's Avatar
Oops sorry, it is an 1985 so 4+3.
Old 01-17-2011, 08:01 PM
0Paul Ruggeri
Former Vendor
I don't know about shortening the shifter, but you can get a short throw kit from the major venders, I have one on my 86.
Old 01-17-2011, 08:08 PM
gkrynick22
gkrynick22's Avatar
yeah. That is going in sometime this week. I also think the shifter lever is way too tall in this car. It should be half as high as it is. I would like to bring it down quite a bit. If worse comes to worse I'll get rid of the reverse lockout. I would like to keep it if I could for obvious reasons.
Old 01-17-2011, 09:48 PM
Black89Z51
Suckin' gas, haulin' ass.
Support Corvetteforum!
Black89Z51's Avatar
I bought the Hurst short-throw shifter from Atlantic Speed. I love it.
Old 01-18-2011, 01:01 AM
gkrynick22
gkrynick22's Avatar
They only make those for the 6 speed. Mine is a 4+3. I don't think anyone makes a custom shifter for the 4+3.
Old 01-18-2011, 03:13 AM
powerpigz-51
powerpigz-51's Avatar
I think it could be done, if you lost the reverse button...here is what I did...I have the short levers, also. The threads on the handle were too small, I had to drill them out to make it fit. It rests in my hand perfectly with my arm on the console. One of the best mods I have done.
Old 01-18-2011, 10:14 AM
littlesk8cracker
littlesk8cracker's Avatar
short shifter on my 6 speed was probablly my favorite mod so far
Old 01-18-2011, 12:16 PM
gkrynick22
gkrynick22's Avatar
That looks great! I want to keep the shift **** and eventually change to the **** with the overdrive switch in it. I find it hard to believe I would be the first to do it. I'll play around with it and if I can do it right I will post a write up with pics.
Old 01-18-2011, 05:54 PM
rodj
rodj's Avatar
Depends what it does to your leverage ratio.
4+3 is not the smoothest shifter with stock ratio; shortening lever would make it stiffer
Old 01-18-2011, 06:16 PM
pmihaltian
Slingshot
pmihaltian's Avatar
Me too. Works well and I did not have any problems with the reverse lock out. $20 at most Corvette parts supply stores.
http://www.ecklers.com/corvette-shor...1984-1988.html
Old 01-18-2011, 07:07 PM
gkrynick22
gkrynick22's Avatar
Thanks for the link, but I already have that. I am in the process of installing them right now. I don't like how high the actual shift lever is, that is what I am trying to get info on modifying.
Old 01-18-2011, 07:10 PM
gkrynick22
gkrynick22's Avatar
Yeah, I was thinking about that when I started doing research on this. That is why I am buying a spare shifter assembly. That way if it doesn't work well I can put the original one back in.
Old 01-18-2011, 07:31 PM
c4cruiser
c4cruiser's Avatar
Think the trick would be to try to remove the handle from where it attaches to the shifter body. Shorten that end and re-attach it. That way you don't have to worry about the upper part with the reverse lock-out ring, the spring, and trying to reattach the handle.
How the handle is attached to the shifter body/mechanism is the part to figure out. If it's pressed in, it may take some effort to pull out.
But once the handle is shortened, you still will have to adjust the reverse cable to make it work.
Old 01-19-2011, 04:44 PM
vettef6
vettef6's Avatar
I have a 6 sp. and have shortened the shifter 1". Don't know if the 4+3 shifter is different. All I can say is, 1" sure made a difference.
Old 01-19-2011, 05:21 PM
gkrynick22
gkrynick22's Avatar
That is a great idea. I was looking at cutting it where the **** was, I never thought of the base. I am waiting for my spare shifter assembly to arrive, then I can get a better idea of how to attack it.
The 4+3 shifter is different from the 6 speed. The 4+3 has a reverse lockout on it (have to lift a lever on the shifter to put it in reverse), the 6 speed does not.
To Anybody shorten the length of shifter
Old 03-06-2012, 12:13 AM
sitko1
sitko1's Avatar
How hard is it to install? How long did it take? I'm thinking about ordering it. Thanks.
Old 03-06-2012, 08:55 AM
LD85
LD85's Avatar
Its easy to do, take your stock shifter, cut 1.0" out of the rod down by the bottom, and weld it back together, done.
I have an old stock rod in my garage, I will try to make one in the next week or so.
I bought one from Hurst when I had the infamous ZF and I put them side by side and the only diff was the length
Old 03-06-2012, 08:58 AM
LD85
LD85's Avatar
I cut my Indy Stick down on the TKO but it bolts to the tranny with two bolts, so I cut it short, then drilled two cross holes and bolted it back on, to make it the same length as the Hurst/ZF shifter.
Quick Reply: Anybody shorten the length of shifter
