Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Old 11-04-2005, 02:46 PM   #1
Scoob
CF Senior Member
Scoob's Avatar
Default Replacing the "door ajar" switch
That's the pin switch on the door that shuts off your interior courtesy lights when you shut the door.
My driver's side switch doesn't work. It leaves my interior lights on.
So I did a quick check of the Helm's manual on this repair. Seems that you have to take most of the door apart to get to that switch. Thanks GM.
Anyone know a short cut for this job or am I really destined for 2-4 hours worth of work to replace this $12 switch?
Scoob is offline   Reply With Quote
Old 11-04-2005, 03:15 PM   #2
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
Yes I do and it worked for me.
After noticing that the tip of the plunger looked a little worn, I applied a little JB Weld Quick Set to the tip, filed it so the depth just increased the effective plunger length a little and no more problem with the "door ajar" light.
If interior lights are staying on it's likely a similar problem with the switch on the door frame. There you can use the same cure or stick a thin piece of metal on the front of the door where the plunger makes contact. Try the latter approach to see if it cures the problem; if so, you may want to use the JB Weld instead of the metal strip as a permenant cure.
__________________
My 1988 Z01 #65 Site
65Z01 is online now   Reply With Quote
Old 11-04-2005, 03:32 PM   #3
Scoob
CF Senior Member
Scoob's Avatar
Interesting and I'll definitely check it out.
Maybe I have my name wrong. The switch I think it is is the one that's on the door very near to the hatch release switch that's on the door.
Anyway, I think that's the problem because when I open the passenger side door and manually depress that plunger switch the interior lights go off. When I do that on the driver's side the lights do not go off.
Old 11-04-2005, 03:32 PM   #4
swifty
CF Senior Member
swifty's Avatar
Really a common problem with these flexible cars - especially the verts. The button / door frame gap just gets a little wider over time or when flexing over bumps and it doesn't hold the button in far enough to open the switch contact. It is a relatively quick fix to put a home-made gasket (rubber, gasket material, etc.) behind the "ears" that keep the switch from falling into the door. No need to remove the door panel. I got this off the forum some time ago.
The only difficulty is if you remove both screws at the same time it can be difficult re-aligning the inside-the-door bezel the screws thread into. So . . . replace one of the screws (I did the top) holding the switch in the door with a longer screw temporarily - leaving it a little loose. Then remove the short screw, slide the new gasket halfway in place and restart the short screw. Remove the long screw, complete placement of gasket, reinstall original short screw and tighten both. Worked like a charm on my '93 vert. You've always got one screw holding the interior bezel in place so it doesn't get away from you.
Good luck, and always look to the CF for the easiest, fastest way to cure C4 blues. There's a lot of experience on board.
swifty is offline   Reply With Quote
Old 11-04-2005, 05:05 PM   #5
rocco16
CF Senior Member
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Quote:
Yep, sounds like a bad switch.
I've taken my switch off without removing the panel, but be forewarned: it's easy to drop the nut plate behind the switch down into the bowels of the door and you'll end up taking the panel off anyway if that happens.
Larry
code5coupe
rocco16 is offline   Reply With Quote
Old 11-04-2005, 07:42 PM   #6
Aaron71771
CF Senior Member
Aaron71771's Avatar
The is a contact piece on the door jam, on a few vettes you can get away with popping it off and putting one or two small washers behind it.
Aaron71771 is offline   Reply With Quote
Old 11-04-2005, 10:15 PM   #7
theadmiral94
CF Senior Member
theadmiral94's Avatar
Location: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
What year Vette? Your profile notes a 90 zr1, is that correct?
Not sure if they changed the door switch that much from 90 to 94 (ours), however, in our FSM/Helm manual, there is a whole procedure for replacing the switch right through it's hole, all without having to take the door apart of loosing the backing plate.
There was even a post about this just a few weeks ago...
Regardless, in the 94 Helm, page 'Doors 10-6-7) it says:
Remove or disconnect the following:
1. lower screw. replace with longer screw started into retainer to hold retaioner from drooping into door.
2. upper screw.
3. pull switch outward and roated switch to expose upper screw hole
4. reinstall upper screw to hold retainer
5. remove lower screw
6. pull switch outward and depress harness lock tab to allow passage of switch and harness throught opening.
7. switch from harness.
basically reverse to reinstall...
One final thought -- I had to replace the switch a couple of times as GM's vendor sucks in QA, poor assembly and/or sticky... so double-check the part before you take it home to install...
__________________
Hope this helps...
theadmiral94 is offline   Reply With Quote
Old 11-04-2005, 11:12 PM   #8
Draven
CF Senior Member
St. Jude Donor '14
Draven's Avatar
Send a message via AIM to Draven
Personally, I threw some money at it. (Yes, thats a quarter taped to the door jam thingy.)
Click the image to open in full size.
It's a temp thing, I need to remove my door panels this winter away.
Draven is offline   Reply With Quote
Reload this Page Replacing the "door ajar" switch
Tags
1968, 1994, 85, 93, ajar, button, c4, corvette, door, install, jam, jamb, light, replace, switch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
