C5 headlight motor question :
Old 10-07-2012, 01:55 PM
fishbust
fishbust's Avatar
Default C5 headlight motor question :
Old 10-07-2012, 02:03 PM
c5BlackBeauty
Corvette C5 Enthusiast
Support Corvetteforum!
c5BlackBeauty's Avatar
St. Jude Donor '05, '12-'13, '15-'16, '21
It may be the headlight gears, which is a common problem. The stock gears are plastic and many Forum Members have encountered problems when the plastic gears essentially grind down. The good news is, if it is the gears, there is a ton of information about replacing with brass. Do an Advanced Search for "Headlight Gears" and you'll get everything you need.
Also, and again if it's the gears, Corvette Mods, a Forum vendor has the gears on sale - free shipping.
Old 10-07-2012, 02:06 PM
guido7834
guido7834's Avatar
It's the gear if it's making a loud grinding noise. I had the same issue. I got the gear kit from Top Down Solutions. Not to bad to do yourself.
Old 10-07-2012, 03:18 PM
fishbust
fishbust's Avatar
Old 10-07-2012, 03:27 PM
Oldvetter
Oldvetter's Avatar
Originally Posted by fishbust
Thanks guys.
The knowledge base on this site is incredible.
Ordered the upgrade from plastic to bronze gear from www.corvettemods.com
The savings for a set was enough to go for it instead of just buying the one. I figure if one is done, the other won't be far behind.
I figured the same, but the other one has been good for years now ! Oh well, I have it when needed.
Old 10-07-2012, 04:20 PM
fishbust
fishbust's Avatar
Old 10-07-2012, 06:44 PM
swpowell
swpowell's Avatar
it's the gears. I got my replacement gears from Rodney Dickman
http://rodneydickman.com/catalog/pro...products_id=92
Here is a good video:
http://www.streetfire.net/video/corv...air_136150.htm
Old 10-07-2012, 08:03 PM
fishbust
fishbust's Avatar
Old 10-07-2012, 09:40 PM
swpowell
swpowell's Avatar
Your welcome
Old 02-11-2013, 04:24 PM
fishbust
fishbust's Avatar
To C5 headlight motor question :
Quick Reply: C5 headlight motor question :
