Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Old 04-28-2012, 02:44 PM   #1
U DREM 2
CF Member
St. Jude Donor '12-'13
Default Change oil light on
Change oil light on. What does this mean? Just had my oil changed last week.
Thanks for your help
U DREM 2 is offline   Reply With Quote
Old 04-28-2012, 02:51 PM   #2
markKlein
CF Senior Member
It means you didn't reset the oil light when you had it changed. The instructions are in the owners manual, and posted in a sticky at the top of the C4 General section.
Sorry, I lied. The sticky is in the C4 Tech section. Anyway, here is what you do:
1. Turn the key to RUN, but don’t start the engine.
2. Press ENG MET on the Trip Monitor. Then, within
five seconds, press it again.
3. Witbin five seconds, press and hold GAUGES on the
Trip’Monitor. The CHANGE OIL light should flash.
4. Hold the GAUGES button until the CHANGE OIL
light stops flashing and goes out. This should take
about ten seconds.
When the light goes out, the monitor is reset. If the
monitor doesn’t reset, turn the ignition off, then try
again.
markKlein is offline   Reply With Quote
Old 04-28-2012, 02:54 PM   #3
Goldcylon
Goldcylon's Avatar
Just reset the light. Which the key in the run postion but not running hit the ENG/MET button twice within a couple seconds of each other. Then press and hold the gaugues button until it flashes and turns off.
__________________
GOLDCYLON - 91 ZR-1 #2014
380 P&P&PCed,Ported Heads,Jeal headers,/Corsas/FIKSE FM-5s /LED TLs, HID Projectors, F/R Baer Eradaspeed Rotors with GS RED/BL calipers,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DOM PROM/ZFDOC Trans,DRLs,BMAD,Coplan Air Blaster,Pioneer AVIC Nav,BreyKrause,HB,SubBar,DRM Coilovers,APSIS CF interior, CF top, Banski trailing arms,guldstrand suspension,ZFDoc safety loop
Goldcylon is offline   Reply With Quote
Old 04-28-2012, 02:55 PM   #4
ch@0s
CF Senior Member
Support Corvetteforum!
ch@0s's Avatar
You need to reset your oil light
Pete made a video its in the stickies at the top of this forum.
ch@0s is offline   Reply With Quote
Old 04-28-2012, 02:55 PM   #5
PLRX
8511 USMC
St. Jude Donor '09-'10-'11-'12-'13-'14
PLRX's Avatar
http://forums.corvetteforum.com/c4-t...oil-light.html
PLRX is offline   Reply With Quote
Old 04-28-2012, 02:59 PM   #6
U DREM 2
CF Member
Thanks all on road trip
Old 04-28-2012, 03:04 PM   #7
RollaMo-LT4
CF Senior Member
St. Jude Donor '10-'11-'12-'13
RollaMo-LT4's Avatar
You didn't list the year of your car.
So, follow Mark's instructions and you might need to replace "Gauges" with "Range" button.
RANGE button (1990-1991)
GAUGES button (1992-1996) on the Trip Monitor
__________________
1996 Corvette - LT4
2011 Camaro SS Convertible
2011 Harley Davidson FLHX Street Glide
RollaMo-LT4 is online now   Reply With Quote
Old 04-28-2012, 03:06 PM   #8
PLRX
8511 USMC
PLRX's Avatar
Well his profile shows a C6, but he posted in here.
Old 04-28-2012, 03:23 PM   #9
RollaMo-LT4
CF Senior Member
Quote:
Oh, that's funny.
__________________
1996 Corvette - LT4
Old 04-28-2012, 04:09 PM   #10
chief bob
CF Senior Member
chief bob's Avatar
Oh, that's funny.
chief bob is offline   Reply With Quote
Reload this Page Change oil light on
Tags
1992, 1996, button, c6, change, changed, corvette, gauges, light, lt4, oil, remove
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
