How to fix the BOSE CD player?
I guess itīs a well known problem: The factory Bose CD players start making problems after 2 or 3 years: First they kind of hesitate to accept CDs at cold weather, then they do it at all kind of weather, then even when the CD is drawn into the slot it will not be played.
I guess it must be a belt drive or something like that. When it gets humid it starts to slip after a while, then it probably gets more and more worn out and slippery, and finally it wont drive the moving parts ny longer.
I guess it must be an item worth only a few cent, but how to access it?
Does anybody know about a simple fix? Are kits available? It must be a quite common problem!
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
Re: How to fix the BOSE CD player? (BrightAquaLT1)
Well it may just be a 10 cent part, however GM will not sell the parts to repair the CD players to anyone other than a GM authorized repair dealer. This sucks because most places charge at least $200.00 to repair the unit regardless how cheap the parts are. :mad :mad :mad :mad
Re: How to fix the BOSE CD player? (Corvette ED)
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Smush it up good! My 1987 has a blown amp; you have to turn the volume **** almost all the way up to hear anything, and it has a lot of interference and scratching at low volume. My 1991 with Bose Gold would not read burned CDs, and occasionally it would stop working altogether! The LED backlight was also burnt out. When it worked it wasn't bad as far as stock systems went.
My new car has all the bose crap ripped out and replaced with a Sony head unit (which I will probably replace), 2 Alpine amps and 2 10 inch Rockford Fosgate Subwoofers. Replacing the system entirely is the best way to go.
Good luck!
Good luck!
:lol:
heres the fix...... "pick it up and throw it as far as you can and don't even look at where it dropped" ........ :D
[Modified by dmalhi1, 5:40 PM 12/31/2001]
I sent mine to United Radio and they charged me $185 to fix the CD Player, put in a new cassette band, a new cassette door, and replaced the lights. I also replaced all the amps with 100's in the back and 75's in the front. It sounds pretty good. I don't need audio perfection! ;-)
Re: How to fix the BOSE CD player? (1990corvette)
My Bose CD has started to give me trouble too. How bad is it to remove the unit? Any helpful suggestions for removing it?
Thanks, Yankee Papa
Thanks, Yankee Papa
Re: How to fix the BOSE CD player? (Yankee Papa)
It's not too hard to remove the unit. The hardest part is getting the snap ring off the auto shift ****!
NC Events Coordinator
I had my CD player fixed/replaced by Dixie Electronics (Charlotte, NC) a few years ago for $115. (I removed/installed the unit myself). For an extra $15 they replaced the belt in the cassette player and aligned the playback head. I know it's a Blowse unit...but it was a HELLuva lot cheaper than replacing the whole head unit, an' i GOTTA have my TUNES!!!
This is my second Vette with the Bose trash. I wouldn't dream of fixing junk. When I can see my way clear I plan to replace it completely. For now I just have radio. :mad Where are all the designers and engineers when you need them. Certainly they must know of this problem. My CD player accepts the CD, doesn't play it then gives it back a couple of days later when it feels like it. :rolleyes:
Fix bose cd player
This post is very old but as many guys have same problems I decided to post a solution. Kits are available - In fact you have to change the laser lens pickup. Disassemble the CD unit to check before ordering parts.
For my BOSE 1993-1996 The parts needed are sold below at a reasonable price of $38. Reference PANASONIC YESFD13002/e13002/13002 tęte laser.
http://fr.aliexpress.com/wholesale?S...D13002&catId=0
Consider 2h to replace the laser pickup. Here under some photos. Small screwdrivers required. Don't forget to remove the antistatic solder.
juni78 (12-29-2019)
I ordered it and the ribbon connections are different sizes.
thanks
Lou
