FS: Comp Cams 280 XFI Hydraulic Roller Cam
..... SOLD ... SOLD ....... For Sale one lightly used Comp Cams 07-467-8 ... 280 XFI HR13 LT1 hydraulic roller camshaft ... the dowel pin was pushed in for a non-LT application ... it can be pulled back out or replaced if needed for your late LT1 Opti drive ... I have the spec card but here goes : Duration at .050 is 230 in / 236 ex ... lift is .576 in / .570 ex using 1.6 rockers ... LSA 113 ... advertised power band is 2000-6000 rpm with intake and exhaust upgrades recommended and 2500 stall converter ... this is a perfect Hot Street cam for 350-400 ci motors ... nice muscular idle but very driveable ... if you are running factory heads , valve springs will need to be upgraded to accomodate the additional lift ... will bolt-in with most aftermarket heads ... I have new in box Comp Magnum pushrods in 7.300 and 7.800 if you need them ... sold separately ... $200 plus shipping for the cam ....
..... Still available ... turns out that Jim needs this grind but on a small base circle for stroker clearance ... this one is a standard sized cast iron core cam ... so you can use regular distributor drive gears ........
