Borgeson box and tilt wheel?
Did a search and didn't find what I'm looking for.
To get the box to fit you need to knock the steering shaft in about an inch or so....I'm guessing that isn't a problem for tilt steering..
Anyone install a borgeson box with a tilt wheel? Any problems?
Thanks
Thanks
No difference tilt or non-tilt re the Borgeson box. You'll need a little over two inches, if memory serves. A good idea is to place some Vise Grips on the shaft about 2" out from the column housing so that when you whack the shaft rearwards with a hammer (don't forget to protect the threads!!!), it won't collapse inwards too far.
Regards from Down Under.
aussiejohn
