? for those with Canton pan/Canton dipstick
Old 02-17-2004, 03:13 PM
93Quasar
93Quasar's Avatar
Default ? for those with Canton pan/Canton dipstick
What did you use to plug the hole in the block where the stock dipstick went?
Old 02-17-2004, 05:22 PM
Ramrod92
Ramrod92's Avatar
Cruise-In II Veteran
Default Re: ? for those with Canton pan/Canton dipstick (Jeff Hickman)
Why would you want to plug it? I'm using the stock dipstick. :steering:
Old 02-17-2004, 09:02 PM
93Quasar
93Quasar's Avatar
Default Re: ? for those with Canton pan/Canton dipstick (Ramrod92)
I'm not using the stock dipstick and I don't want oil to pour out. My windage tray does have the hole in it for the dipstick to pass through. But I can't get the dipstick to hit the hole. So it won't read any oil. I think it is mainly due to the way I have the tube bent for the headers. So I said screw it and I bought the canton dipstick that threads into the fitting on the top side of one of the wings of the pan. The new dipstick works great. But I didn't see the point in leaving the stock dipstick in the block and would prefer to just plug the hole. Not that it will probably hurt anything having two dipstics - one that works and one that doesn't. Just seems goofy and why clutter up the engine bay. I thought there might be a plug out there somewhere for this purpose, rather than having to fab something up.
Old 02-17-2004, 10:54 PM
Ramrod92
Ramrod92's Avatar
Ok, got it now. I can't think of any good option. :confused:
Old 02-17-2004, 11:12 PM
Pete K
Pete K's Avatar
If memory serves, 5/16 cap plug. Use 2, one on top of the other. check bottom of dipstick with open end wrench to be sure. :chevy
Old 02-18-2004, 03:11 PM
speedjohnson
speedjohnson's Avatar
Default Re: ? for those with Canton pan/Canton dipstick (Pete K)
Just knock in a small soft plug.
Old 02-18-2004, 03:17 PM
LD85
LD85's Avatar
Default Re: ? for those with Canton pan/Canton dipstick (speedjohnson)
I had to clearance my oil pan ot get my dipstick to hit the oil and miss the pan ledge.
Old 02-18-2004, 03:20 PM
93Quasar
93Quasar's Avatar
Are you referring to something similar to a small freeze plug? The hole is a couple thou less than 3/8. So maybe a 3/8 plug will do the trick. Sure don't want it to fall in though.
Old 02-18-2004, 03:27 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
That worries me :confused: make sure the tray is aligned.
To check this use a shorter length of rod to see if they're inline or not.
You can get flexible dipstick tubes.
http://www.lokar.com
Summit catalog page
Old 02-18-2004, 04:05 PM
93Quasar
93Quasar's Avatar
Default Re: ? for those with Canton pan/Canton dipstick (BrianCunningham)
The tray is fixed into the pan and really doesn't have any adjustment. I could have enlarged the hole or clearanced as ID85 did, but didn't look at this in advance. I think for now since I have a working dipstick option it is best to just plug the hole.
To ? for those with Canton pan/Canton dipstick
Quick Reply: ? for those with Canton pan/Canton dipstick
