Seperate cd player
Seperate cd player
Fellas,
Don't laugh, how do I connect a cd player seperate from any dash use. I want to run a power wire from the battery to a cd player and box speaker to the back of a 66. Sounds easy but I am ready to duck tape my head. I do need a step by step procedure.
Thanks,
Thanks,
Attached is a pic of a 65 fuse block. you can see the post labled "ACC" - run that to the switched power wire (yellow) on the radio. Below it is a "batt" post, run that to the constant on (red) wire on your radio... run a ground and it will power up.
