replacing clutch fork rivet
Old 01-18-2008, 09:17 PM
fisheson
fisheson's Avatar
Default replacing clutch fork rivet
anyone have a source for the rivet in the clutch fork when replacing the bearing spring?? and repair??.............thank you
Old 01-18-2008, 10:31 PM
vetteking62
vetteking62's Avatar
Default rivet
Go to your nearest farm supply ( JD, NH, Case etc. ) Rivets are used on hay mower knives.
Old 01-18-2008, 11:16 PM
fisheson
fisheson's Avatar
Really? i just happen to own 3 case heavy equipment pieces,i would never of have thoght that way!! i really like THIS place!!...........thanks
Old 01-19-2008, 12:02 PM
GCD1962
GCD1962's Avatar
Dr Rebuild has the spring and rivit
Old 01-19-2008, 01:31 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,859 Likes on 1,102 Posts
So does Paragon.
Old 03-31-2012, 09:24 PM
C6Matt
C6Matt's Avatar
Originally Posted by JohnZ
So does Paragon.
I know this is old, but what is the best way to install the rivit?
To replacing clutch fork rivet
Quick Reply: replacing clutch fork rivet
