Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Old 05-06-2007, 08:01 PM   #1
Randy C
Junior Member
Randy C's Avatar
Default 1966 stock size steel wheels
I am just in the process of blasting and painting the wheels on my 66 and it turns out that they are 15 x 5.5's. is that correct for the stock steel 1966 wheels?
Randy C is offline   Reply With Quote
Old 05-06-2007, 08:44 PM   #2
vettes1st
CF Senior Member
St. Jude Donor '06
Yes!
vettes1st is offline   Reply With Quote
Old 05-06-2007, 08:45 PM   #3
JoesC5
CF Senior Member
Yes. 63-66 are 15 X 5.5 and the 67 ralley's are 15 X 6. KO's are 15 X 6.
JoesC5 is offline   Reply With Quote
Old 05-06-2007, 09:22 PM   #4
Randy C
Junior Member
Randy C's Avatar
Thanks!
Old 07-14-2007, 05:41 AM   #5
Nev Williams
CF Senior Member
Nev Williams's Avatar
Neville Williams
Send a message via Skype™ to Nev Williams
Quote:
Would anyone happen to know what the offset is supposed to be on these? Is this measured to the very outer edge of the rim?
When car is jacked up at rear with daylight under between the tyre and floor I have the transverse spring end interfering with the RH rear rim.
I'm just wondering if the rims have the correct offset.
Neville
Nev Williams is offline   Reply With Quote
Old 07-14-2007, 10:52 AM   #6
66since71
CF Senior Member
66since71's Avatar
Spring shouldn't interfer.. If no one has the data handy, I'll dig out my original rims and measure them for you.. I'll follow the thread..
66since71 is offline   Reply With Quote
Old 07-14-2007, 11:37 AM   #7
66since71
CF Senior Member
66since71's Avatar
back spacing should be 3 5/8" (just measured my originals)
That is measured from the inner most edge of the rim to the mounting surface.
Old 07-17-2007, 03:25 AM   #8
Nev Williams
CF Senior Member
Neville Williams
Thanks for this.
I will measure wheel, when it comes back from Compliance test and add to thread. They also picked up this wheel interference and reckon the spring is not centred. It looks centred to me. They seem to think it is just a matter of moving the spring. I do not think it is as simple or as easy as this somehow
Neville
Old 07-17-2007, 12:31 PM   #9
toddalin
CF Senior Member
Quote:
Originally Posted by Nev Williams View Post
Thanks for this.
Neville
As I recall, there is a small hole in the center of the spring with a nut/bolt that holds the spring elements together. The bolt fits into a small locating hole when the spring is mounted. Any side to side movement will be extremely small (<1/8") due to this locator.
Sounds like you need a shop that knows Corvettes.
toddalin is offline   Reply With Quote
Old 07-18-2007, 01:27 AM   #10
Nev Williams
CF Senior Member
Neville Williams
All sorted in no time.
I will get to see tommorow when I get to pick the car up, all registered to legally drive on our roads Yeeehaaaa.
I have of course driven it illegally but now I can go down a decent stretch of highway and have some fun and no doubt also find out a few other things that need fixing.
I'm sure the wheels need aligning but that will have to wait until I install all the new bushes etc.
Old 07-21-2007, 06:33 PM   #11
Nev Williams
CF Senior Member
Neville Williams
Have measured the offset
102mm (4") If your wheels are orig standard that makes mine from something else. That extra 30mm (3/8") is obviously making clearances to tight. With a forty year old car these wheels could be off any GM car.
This might be a good time to start thinking replacing with a nice set of alloy wheels and tyres !!
Click the image to open in full size.
Old 12-03-2012, 08:36 PM   #12
aussievett
Junior Member
1966 tyre sizes, I am looking to buy some white wall tyres will 215/70/15 fit on my 66 vett without rubbing or should I go 205/75/15 they are steel wheels. What looks the best?
aussievett is offline   Reply With Quote
Old 12-03-2012, 11:57 PM   #13
Hitch
CF Senior Member
Support Corvetteforum!
Hitch's Avatar
WOW a thread that is 5 years old!!!!!! lol
Hitch is offline   Reply With Quote
Old 12-04-2012, 08:04 PM   #14
JohnZ
CF Senior Member
Quote:
Either size will work - however, with 205/75's, there is ZERO chance for any rubbing under any circumstances. With 215/70's, rubbing is possible at full steering lock and suspension compression (like entering a driveway).
JohnZ is online now   Reply With Quote
Old 12-10-2012, 07:49 PM   #15
anglerjon
Junior Member
anglerjon's Avatar
I put 205/75s on mine, think it looks about right, could be a little tight with 215x70s
anglerjon is offline   Reply With Quote
Reload this Page 1966 stock size steel wheels
Tags
15, 1966, 55, corvette, dimensions, size, steel, stock, wheel, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
