Sponsored by: DashLynx
FS: MTX Thunder 4244 4 Channel amp
Old 06-11-2010, 08:23 PM
XtremeVette
NCM Bash 2008-2018
Support Corvetteforum!
XtremeVette's Avatar
Location: Granby, MA Talladega Super Speedway Vettes 4 Vets Ambassador
Middle TN Events Coordinator
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default FS: MTX Thunder 4244 4 Channel amp
For sale 1 used in good condition MTX Thunder 4244 4 Channel amp
Amp was removed from car and was working just fine when removed.
Specs:
RMS Power Output (Watts x Channels) 45 x 4
Peak Power Output (Watts x Channels) 55 x 4
Power at 2 Ohms (Watts x Channels) 60 x 4
Bridged Power (Watts x Channels) 120 x 2
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Best Frequency Response 20-20kHz Hz
THD at Rated RMS Power 0.1%
Signal to Noise Ratio 100 dB
Input Voltage 12.5v
Features
Amplifier Class A
Low-Pass Crossover Frequency 85 Hz (rear)
Low-Pass Slope (dB/octave) 18 dB
High-Pass Crossover Frequency 85 Hz (rear/front)
High-Pass Slope (dB/octave) 18 dB
Bass Boost No
Bass Boost Frequency N/A
Fan Cooled No
Fuse Rating 25 x 2
Speaker Level Inputs Harness
Preamp Outputs 1 pair
LED Power Indicator Yes
Width (inches) 11-13/16
Height (inches) 2-1/4
Depth (inches) 9-3/4
Selling for $60 shipped anywhere in the US
This is a good shipping deal (the amp weights approximately 15lbs)
I accept Paypal with no fees
Old 06-13-2010, 05:18 PM
XtremeVette
NCM Bash 2008-2018
bump
Old 06-14-2010, 02:00 PM
XtremeVette
NCM Bash 2008-2018
bump
To FS: MTX Thunder 4244 4 Channel amp
Quick Reply: FS: MTX Thunder 4244 4 Channel amp
